Originally posted by Ovation
I think I found my new Pre/Pro Denon AVR-4311CI
I have a Sony MiniDisc home deck (I've had it for years and I still use it regularly). I also have an external soundcard for my computer that has a digital optical input and I've fed it with broadcasts from my cable box of classical and jazz concerts from CBC radio to archive on my hard drive.Originally posted by impala454Just curious here, what do you do with the optical output?- Bottom
ok nevermind.. got the answer here, pretty good info!
http://www.gspr.com/onkyo/onkyo3thx.html-Chuck- Bottom
my thoughts is if your going to use it as a pre/pro and turn the internal amps off then why spend the money on a receiver. The circuitry inside a receiver isn't as good as a dedicated pre/pro. You can get a nice used rotel pre/pro for $1200 and then purchase used amps. You will have 10 times the system. You can even get a used classe amp in the 2K range. so for 3200 you would have a system that blows away a denon receiver- Bottom
why would you want 9.2.. there is no such thing. there is no media above a 7.2 which is very limited at this time. There are very few chip boards out there that are able to upgrade 5.2 to 7.2 sound and they are in the minimum 10K range. So I know denon doesn't hold the secret to upgrade a 5.2 signal to 9.2. It's a marketing gimmick and you will never need more than 7.2 in any room- Bottom
Well, garrison, the same thing was actually said when we went from DPL to 5.1. Then to 6.1, 7.1.
7.1 DISCRETE channels is the most we have right now (not 7.2). (unless you count something like motion data added by certain manufacturers) However, processors can use algorithms to extract any number of other channels, as they are designed. DPL IIz technology indeed can do 9.1 matrixed channels. Combine that with Yamaha technology, and yes, you can do 11.1 matrixed channels. More are possible. To say that any particular number is "the most you'll ever need in any room" is a matter of personal preference in relation to existing technology. THX would love to add a discrete ceiling channel, making 8.1. If they did, would any particular people be saying "no, don't use it... we've already declared 7.1 the most you'll ever need"?
- Pleasantville- Bottom
I'm totally guessing here, but I don't think there's any used rotel prepros for $1200 that have HDMI 1.4, as well as all the other features I'm looking for that the onkyo has (or the denon for that matter). I would love to find a good prepro that has everything I want that doesn't cost $5,000, but so far that doesn't exist. Which is kind of sad as I don't want that much... just 4 or 5 HDMI ports, decoders for all the latest codecs, balanced outputs, 12v triggers, serial control, and enough other inputs for all my stuff. Doesn't seem like that much to ask. I already have an awesome amp, just need an awesome prepro to go with it.Originally posted by garrisonmy thoughts is if your going to use it as a pre/pro and turn the internal amps off then why spend the money on a receiver. The circuitry inside a receiver isn't as good as a dedicated pre/pro. You can get a nice used rotel pre/pro for $1200 and then purchase used amps. You will have 10 times the system. You can even get a used classe amp in the 2K range. so for 3200 you would have a system that blows away a denon receiver-Chuck- Bottom
Also there are tons of pre/pro's receivers and the likes out there that can "upgrade" as you called it 5.1 or 7.1 to 9.1 or 11.1. You'd have to experience the setup your self to understand why.
And yeah Chuck I don't think I've seen any Rotel processors for 1200 that have HDMI at all, although I haven't looked in a while.... Generally I find Rotel to be a bit over priced? But to each their own. Classe and Parasound I like but out of my price range and neither have the current features.- Bottom
Well it looks like the 4311 may be high on my list of options again... I'm really not sure and it'll come down to spur of the moment and me deciding how much I want to spend
The 4311 can already be had for 1500 quite a few places though.
by Bam!Hey guys!
I would like this thread to be about great Pre amps and amps......budget not being an issue
So post on the name, price....and your comments on it :P
Recently I listened to Rogue
Here is the front of the Amp...all in tubes
Channel: Audio Hideout
by ou8thisSNNone of their Pre-amps have the THX surround processing mode, yet all the powerful amplifiers have THX ultra certification. Wonder why...-
Channel: Club Rotel
by BluespowerCan anyone recommend a universal remote (make & model) that works with remote controlled 900 series pre amps? I'd be happy with just volume & mute.-
Channel: Club Rotel
by Andrew PrattI know this could likely have gone in the Club Rotel but I wanted to show people that receivers can make decent pre amps in some cases....
As luck would have it I am presently lucky enough to own both the Rotel 1055 receiver and the Rotel 1066 pre amp. For those that don't know about...-
by EliavHi guys, I need your advice.
I am currently feeding the CAM 400 with the rotel 1068. I want to keep it for movies and get a GREAT two channel pre to match the CAM400. The problem is that most higher pre amps cannot be hooked up to the 1068 to work as one system ( as far as I understand).
- Loading...
- No more items.
