Audio 7.1 question
  • tallcool1
    • Sep 2008
    • 5
    Audio 7.1 question
    I have a parasound preamp with one set of 7.1 analog inputs (no HDMI). It is currently used with my DVD-A player. Now I am going to buy a blu-ray player and need to use the 7.1 analog connection for that too. Would the sound be degraded significantly by just using Y adapters so each input can be connected to both the DVD-A and the blu-ray? Or would it be "much" better to buy an audio switcher like the Zektor mas7.1?
    Thanks!
    Ted
    YES, to my knowledge, you can't use y-plugs to hook two sources to one input. You can only split an output.
    Sorry, unless I'm dramatically wrong, (which is always possible) you'll need a nice switch--the Zektor works great, everyone says.
    • Mike Hayes
      DVDA/SACD Connections to 1066
      by Mike Hayes
      I am considering purchasing a Pioneer 563A ($180) universal player to replace my Toshiba SD5700. I am currently using just the digital connection (not using the 5 analog cables for DVDA). This will be my first experience with DVDA/SACD in conjunction with my 1066 so please bear with me.
      03 August 2003, 09:53 Sunday
    • Danbry39
      Help on setting up for DVDA
      by Danbry39
      Just bought my first DVDA, Vivaldi's Four Seasons, and need to know how to set up the Rotel 1066. Denon 1600 DVD player to output DVDA. Right now, I've placed the disc in the 1600 and sound seems to come out of all speakers after I pushed the Multi Imput button on the Rotel's front panel. The display...
      16 March 2003, 15:58 Sunday
    • Burke Strickland
      Gone with the Wind (BluRay)
      by Burke Strickland
      Celebrating its 70th anniversary, the studio that currently owns Gone with the Wind has released it on BluRay in a multiple-disc special collector's edition that includes a ton of extras (well, at least a couple of pounds of extras, some printed, others on the addtional discs) in the oversized box,...
      21 November 2009, 19:43 Saturday
      Bluray Audio Format Confusion
      by Johnloudb
      Okay, all these different audio formats have always confused me. On the back of this Jeff Beck Bluray disc "Live at Ronnie Scotts" it lists the audio format as LPCM stereo, Dolby Digital 5.1, DTS HD Master Audio.
      LPCM (Lossless Pulse Code Modulation) Stereo, is...
      17 April 2009, 18:33 Friday
    • Joe Fagan
      1570 won't play BluRay disc properly. Help
      by Joe Fagan
      Tried to play my first BluRay disc tonight and am having problems. The BluRay disc is the current Star Trek movie. The Oppo BD BluRay displays True DD. The 1570 displays Dolby HD Dmix 48k with subscript showing only the FL FR and SW playing. When I turn 1570 off and then on again that first display...
      22 December 2009, 20:09 Tuesday
