Is there a hard reset sequence/combination?
Hard Reset for Denon AVR-988?
by crash_3174Hi I just got a Denon AVR988 off ebay and it is having issues. The receiver will make clicking noises and the front panel will display "H/P Input On" and the sound will go off, it will click again and display "H/P Input off and the sound will come back on. It does this randomly and if...-
by aredantI have a RC-418M remote control that I use with my DTR7.1 receiver.
It's not unusual to accidentally press the wrong keys, but this unit seems to be stuck in limbo mode. It was stuck with the display "M-09". Could not cancel out. I followed the directions to reset. Hold down ON/RESET... -
by Andyc63Is there a hard reset sequence/combination on the Denon AVR-988?-
Channel: Audio Hideout
28 June 2008, 08:09 Saturday -
by CushieHi all. I'm having an annoying problem with the AC power switch on my RX-1050. It's a spring-loaded push button, and occassionally doesn't lock in the 'on' position. If I hold the button in all works fine - I hear the power supply relay fire, and then the speaker relay - but let it go and it pops right...-
Channel: Club Rotel
29 December 2004, 13:08 Wednesday -
by randalHi All,
Any suggestion where I can buy the 3PDT switch with long neck
As you know this monitor statement (yeah ... I know, i hold this project too long) using 3/4 inch of MDF. All of the HS locally their pdt neck is short
can some one pls let me know where to get it?...-
Channel: Mission Possible DIY
- Loading...
- No more items.
