PS3 firmware 2.30 adds DTS-HD Master, High Resolution Audio
  • nikos
    • 172
    http://blog.us.playstation.com/2008/...e-walkthrough/ http://blog.us.playstation.com/2008/...e-walkthrough/
    Quote"
    We know you’re all patiently waiting for the next PS3 firmware update, ver. 2.30, which includes the revamped PLAYSTATION Store.
    I have more good news to report today – the system software update will also add DTS-HD Master Audio output for Blu-ray videos, which means the high-definition visuals of Blu-ray will now be matched with the highest quality audio for the ultimate movie-watching experience on PS3.
    DTS-HD Master Audio is literally bit-for-bit identical to the studio master recording and makes movie soundtracks and sound effects truly come to life. The technology delivers audio at the incredibly high rate of 24.5 mega-bits per second (Mbps) on Blu-ray disc, which is significantly higher than standard DVDs. DTS-HD Master Audio also offers 7.1 audio channels at 96k sampling frequency/24 bit depths, so you’ll be totally immersed in the sound. The firmware update will add DTS-HD High Resolution Audio as well, which is a similar output technology that requires less disc space. You can read more about both codecs here. "
    Looks like the PS3 is the best Blu-Ray player after all....
    I think its time I add it to my collection next to the 360.
    N
    Classe SSP-800, Classe CA-5200, B&W 803D, B&W HTM2D, JL Audio Fathom f113 Subwoofer, Rotel RMB-1077(for sale), Oppo DV-983H, Panasonic PT-AE900U Xbox360, Sony PS3, Samsung 8000 Series 55" LCD, Klipsch promedia 5.1 ultra for PC
    • 1540
    The PS3 has been hands down the winner in the BR battle IMO. The support is next to nothing. I have never seen or heard of such backing.
    B&W
    • georgev
      • 365
      When is the firmware coming out?
      • Dmantis
        • 1037
        I can't agree with you more. It's also the fastest loading.
          Should see the firmware on 15 April, just 3 days! Tuesday!
          • cxc21
            • Mar 2008
            • 107
            Quote"
            N
            How will the PS3 put out the DTS-HD master audio? Decode internally and output 5.1 or 7.1 analog? As PCM on the HDMI connection?
              For now, (and unless the PS3 gets HBR capability someday in the future) the PS3 will decode DTS-MA internally and output as decoded PCM over HDMI. The PS3 doesn't have multichannel analog outputs.
              • Azeke
                • Mar 2003
                • 2123
                The 2.30 version is currently available, I guess it's time to update the firmware and test the results. Only wish it had multi-channel outputs to test the DTS-HD capability. Oh well, you can't have everything, where would you put it. Thanks for the headsup.
                Peace and blessings,
                Azeke
                  • 16128
                  Your receiver doesn't support PCM over HDMI?
                  • maseline_98
                    • 317
                    Mine doesn't, but i wish it did....I would have definitely snagged a ps3 up if that was the case....but would be truly ideal is if sony would release a 'dongle' of sorts with 7.1 analog outputs....if that was the case, they would have had my $600 long ago...
                    Sony kds-60a2000\Panasonic BD-55k\XBOX 360 Premium(20gig)Slingbox\Xbox(flashed) running XBMC
                    Emotiva UMC-1\Emotiva XPA-5\Klipsch (2)RF-7s with DeanG xover upgrade, RC-7 with DeanG xover upgrade, (2)RS-7s\SVS 20-39PC+
                    _____________________________
                    “Insanity: doing the same thing over and over again and expecting different results.” - Einstein
                    • Azeke
                      • Mar 2003
                      • 2123
                      Unfortunately, neither does mine, the HDMI is video only.
                      Azeke
                      • maseline_98
                        • 317
                        Does it matter what version of HDMI a receiver has(I might actually purchase a receiver with HDMI 1.2, but I want to make sure I'm not buying obsolete technology).
                        EDIT: Nevermind....found a google answer...guess i'm not buying that receiver...
                        • littlesaint
                          • 824
                          My receiver is 1.2. No problems at all. You only need 1.3 if you want bitstream audio, which is not necessary if your player can decode HD audio, like the PS3.
                          Santino
                          • maseline_98
                            • 317
                            Can it do TrueHD and DTS-HD MA? The model I was looking at was the Marantz SR-8001 to replace my SR-8400(strange going backwards in model number brings new features).
                            • littlesaint
                              • 824
                              The receiver doesn't have to if your player decodes it internally. All the receiver has to support is multi-channel PCM over HDMI which is part of the HDMI 1.1 spec.
                              There are players that do not decode internally, so you'd have to check, but in the case of the PS3 which does not output bitstream anyway, an HDMI 1.3 receiver is not necessary.
                              Santino
                              • georgev
                                • 365
                                Does the PS3 send the decoded HD content only via the HDMI or also via the optical out?
                                • cxc21
                                  • Mar 2008
                                  • 107
                                  Toslink protocol doesn't have the bandwidth for HD master audio.
                                  • georgev
                                    • 365
                                    So the only way to make use of the PS3's decoding capability is to have a receiver/pre pro that can decode it via HDMI?
                                      Yes.
                                      • Tomahawk
                                        PS3 + RSP-1570 and Master audio?
                                        by Tomahawk
                                        Hi.
                                        I have connected my PS3 with HDMI to my Rotel RSP-1570.
                                        The PS3 sound settings are set (Settings->Sound setting->Audio Output Settings ->HDMI-Automatic->Setting List, and all options are ticked off).
                                        When playing a Blu-ray movie with DTS-HD Master...
                                        17 July 2010, 10:49 Saturday
                                      • tpirovol
                                        RSX-1550/1560 & PS3
                                        by tpirovol
                                        Hi Everyone,
                                        Just wondering what settings I should use to send Truehd and DTShd to my 1550? Also does the ps3 send un-decoded truehd and dtshd to the 1550?
                                        Thanks Terry
                                        26 January 2009, 15:44 Monday
                                      • madmac
                                        PS3 internet sucking problem!!!
                                        by madmac
                                        Hey Folks,
                                        Lately, I've been using my PS3 for DVD and BD playback but I've run into a problem. My PS3 connects to my phone's wi-fi hotspot when I start it up, sucking huge amounts of data in the process. I have no internet at my apartment and use my phone's 'hot spot' for connecting to...
                                        24 February 2013, 14:00 Sunday
                                      • bnieman
                                        Is DTS-HD MA possible with PS3 and RSP-1068?
                                        by bnieman
                                        Hello!
                                        I currently own a Rotel RSP-1068 and am considering a PS3 for Blu-Ray playback. It's my understanding the PS3 can now decode DTS-HD MA and send it over HDMI or Optical as a LPCM uncompressed signal after a firmware update released in late April of 2008.
                                        Is this true?...
                                        02 September 2008, 14:51 Tuesday
                                      • Guybrush
                                        Rotel RSP-1069 and Sony PS3
                                        by Guybrush
                                        Hi to all. Thanks to the help of hifiguy and KevinD my RSP-1069 is working perfectly and now I can focus myself on settings and performance.
                                        The first thing I noticed when I started listening to movies were the high frequencies, much more present and detailed if compared to my previous RSP-1066....
                                        24 September 2009, 14:02 Thursday
