What's the difference between analog audio using twin rca cables vs. an fiber optic cable other than the decoding? Does it effect the signal strength from DVD to receiver? If I were to listen in stereo mode or pro logic on the digital line, would it sound any different than the rca lines?
The current setup is rca lines. It is difficult to get good cables here... third world country. There is a crackling sound when the volume is turned up relatively low. This crackling does not exist when the dvd is hooked up to an older carver receiver. Is there any explanation?
