arcam 300 and arcam p90 works fine together?
  • taoyeah
    • 11
    i just bought a pair BW 805S ,is there alot different if i biamp it than biwire ?
    i got a arcam 300.if biamp,the p90 is a good choice?
  • srusmantijo
    • 3
    Arcam & BW speakers
    I have a similar setup. I have used Arcam AVR300 with N804, HTM2, Velodyne basic sub and JBL cheap surround. It works great.
    Since I don't use the 6&7 ch, I use them to bi-amp the N804. And, bi-wire the HTM2 (center). You should check the arcam owner forum, there's a lot of info in there. Hope this helps.
    • taoyeah
      • 11
      thankyou.
      • taoyeah
        arcam 300 and arcam p85 works fine together?
        by taoyeah
        02 January 2007, 09:14 Tuesday
      • jayman_1975
        gonna buy an amp
        by jayman_1975
        Hi all. I am in the market for a good amp to add to my Arcam ARV300. I was trying to snag an Anthem MCA-5 on Ebay but got scooped last minute. I think now I will focus on a strickly 2 channel amp as that is what I am most wanting to improve upon. My set-up is as follows. Arcam AVR300, Arcam DV27+ ,coax...
        26 December 2007, 18:45 Wednesday
      • luszer
        Sig 805 vs N804
        by luszer
        Trying to extract some info on what is a higher fidelity solution. I currently have n805 and not sure if the upgrade to 804s or Sig 805s would be worth the effort and extra $$.
        Will I hear a marked improvement in soundstage, smoothness, realism and overall silky presentation going...
        15 November 2004, 15:01 Monday
      • akhter
        HTM2 or HTM4s with N804
        by akhter
        My dealing is offering the old HTM2 for 850, and the new HTM4s for 1350. I would have gladly jumped for the old ones, but they are in natural cherry and my N804 are Red Cherry. So he suggested the new ones in Rosenut. Natural cherry is not an option in my living room (I know I know) and even a black...
        10 August 2005, 13:26 Wednesday
      • miner
        Do I really need a sub with N804?
        by miner
        After 3 weeks of usage my N804 are starting to open up. Previously I had Polk Audio RT20p with built in sub (2 - 8" / speaker). I was really missing the lower end with my N804 initially but have almost decided against the sub while listening last night. The bottom end is beginning to open up,...
        09 April 2005, 08:28 Saturday
