Bridging amps and 4 ohm loads
  • kgveteran
    • 865
    What is it about a 4 ohm load that gives the amp a hard time in bridged mode ?
    What if the amp has enough power and the 4 ohm load really only goes from 100hz on up.
    Is it that no matter what I do, the amp will be stressed out by this load ?
    This is my project for the summer as movie watching falls off the edge.I'm buying three Ashly FET-200's.My plans are to transplant all three under one chassis.Why...I'm not sure. I have owned them in the past and they are a nice class AB mosfet design and if the amp is beatup real good I can get it cheaper.it's the insides i want.This will give me three mono channels that only share the 120vac/20a electrical connection.They are a fan cooled design, so the heat sinks will be mounted on the outside of the chassis.I'm figuring about 385 watts mono into 8 ohms (X3) and i'll be driving three RS center channels from the DIY thread. I can get each one for anywhere from 120.00 to 150.00 dollars. There is a used audio store in town, I'll be going there to find them.Thats where I got the idea.Why not just plop down each one and be done with it ? Good question !
    I wasn't aware that this was a regularly occurring issue. Is it? If so, that's a good question.
    Shoot, there's nothing wrong with building a better (read "less expensive") mousetrap - or amp. If you can get three mechanically sound amps, replace their damaged casing with a good one of your own and come up with a good performing unit for less money then more power to ya! :yesnod:
    • Glen B
      • 1106
      When an amp is bridged, it "sees" half the normal load impedance, Therefore, an 8-ohm load appears like 4 ohms and a 4-ohm load appears like 2 ohms. That is because in bridged mode the amp delivers twice the voltage and current (as in unbridged mode) to the speaker.
      • Kal Rubinson
        • 2109
        Yes, and how 'stressed' the amp is will depend on its design and how much current it can deliver into low impedances. Some have the capability and some do not.
        Kal
        Kal Rubinson
        "Music in the Round"
        • kgveteran
          • 865
          Kal
          I guess what I can do is integrate them into the system one at a time, if all goes well, the project can continue.
          I would like to get a hold of one of those Cello amp cases.They are huge.It would match my huge Outlaw 990.
          Thanx for the input!
          • Kevin P
            • 10812
            You'll be ok if you use an amp that can drive 2-ohm loads unbridged, in bridged mode with a 4 ohm load.
            • kgveteran
              • 865
              I think I'll email the tech guys at Ashly and see.They should have some idea.Tha t makes a world of since about driving a 2 ohm load.
              • alebonau
                • 992
                jsut one thing too, I've found bridging an amp can completely change its chrecter. a rotel 1066 6ch amp for instance that we bridged once for a demo made it coarse, forward hard to listen to, hardly the rotel charecter I'm familiar with. I believe briding amps double its distortion as well. Perhaps somethign impacting on sound as well. there are some awesonme bridged amps though the mightt elctrocompaniet nemos that abbey road used to drive their reference B&Ws I think from memory were two electrocompaniet amps bridged to form the monoblocs. So yeah guess theres always excepetions ?
                • kgveteran
                  • 865
                  More food for thought, after a great lunch of sushi. Thanx guys.I will take all this in concideration.Ashly also made a FET-500. 250 watts perchannel.I've seen them around also.Same design but more output transistors.I think they used Toshiba mos-fets...I think
                  • MarkAR9LS
                    Can the A21 drive 2 ohm loads?
                    by MarkAR9LS
                    I've been lurking for a while now and thought it was time to step out of the shadows.
                    I was wondering if the Halo A21 amp could realistically drive a 2 ohm load.
                    I have a pair of AR-9LS speakers (4 way 5 drivers) that I plan to tri-amp (via a DEQX...
                    15 May 2006, 05:20 Monday
                  • mike.g
                    Will RSX-1056 improve with a RB976 amp and does rsx1056 = rsp1066
                    by mike.g
                    I have a RB976 6 channel amp
                    http://europe.rotel.com/support/pdfs/manuals/Rb976.pdf
                    It drives my M&K k17's and K4's all of which are rated at 4 ohm.
                    The amp's specs are rated at 4 ohm and it is very clear the amp should and can drive 4 ohm speakers on all channels....
                    29 March 2007, 04:16 Thursday
                  • drosophila
                    Ack! Mired in Amp-Land!
                    by drosophila
                    I'm plotting a new home theater setup and could use some help. Time and again throughout my research, i'm hitting a roadblock on the amplification side. Speakers are 4 Epos M5's (4 ohm - to be used as fronts/rear surrounds) and an M8 center (8 ohm). I'll be honest - my difficulty is largely my own...
                    11 December 2004, 01:17 Saturday
                  • gc8ej25
                    Bridged RB1070 for HTM3S?
                    by gc8ej25
                    The recommended power for the HTM3S is 50-250W and I have an RB1070 available to power it. In bridged mode, this amp puts out 330W at 8 ohms. Is this overkill or damaging for the speaker if the levels are within reason? Thanks in advance, guys.
                    22 April 2008, 21:24 Tuesday
                  • stuofsci02
                    B&W 801D
                    by stuofsci02
                    All,
                    I have the opportunity to pick up a pair of 801D's that were traded in on a pair of 800Di. These 801D's are a couple of years old and are in mint condition on display at my dealer. He wants to sell these and is willing to deal. I believe I can get them taxes in delivered for ~$10k...
                    31 August 2012, 19:43 Friday
