Help with OSD function
    I am seriously considering buying a used Rotel RSP 976 pre/pro in order to upgrade my current 2 channel component system to 5.1 HT. As a novice, I have been studying for a few months, but still have much to learn and rely on advise from nice folks like you.
    I am in a quandary over the purchase of this unit. My current TV, which will not be replaced any time soon, has only composite and S-Video inputs. I have found information that says the RSP 976 OSD (On Screan Display) only works with the composite format. If this is true, does this means that in order to make use of the OSD, I have to sacrifice using the higher quality S-Video signal to my TV? As I said, I’m no expert, but this does not make sense to me?!?
    Following is the correspondence I have had with the seller:
    Question to seller:
    "I saw a review by an owner on audioreview.com that said his OSD did not work when using S-Video I/O cables, Sounds like 'bunk' to me, but can you confirm? "
    Reply from seller:
    "As for the S-Video thing, the OSD does not work with it. I have the OSD on and connected both S-Video and composite out and the OSD only showed up on the composite output."
    At this point I am totally confused. I can buy this unit for $400. I would ‘seal the deal’ in a minute if I can get this issue resolved.
    Any and All advice will be greatly appreciated.
  • locomk
    • 91
    you only need the osd to make adjustments and change settings such as speaker size and levels, you wont really need it for anything else and a s-video connections will not make a osd look any better or make it anymore usefull, save the s-video input on your tv for your dvd player and other components, you can still use s-video switching in the rotel and just have to change the tv to the composite input for the occasional tweaking of your settings using the osd.
      Thank you so much for the info!!!!
      This is all starting to make sense thanks to help from great people like yourself.
      I hope I can return the favor some day.
      • locomk
        • 91
        we all started somewhere, anytime
          by wkhanna
          I am in a quandary over the...
          21 January 2006, 10:57 Saturday
        • Jaime
          rsx-1055 osd problems (HELP!)
          by Jaime
          Hello all, I'm having problems with my osd, everytime I press the osd (menu) button, I get kind of a scrambled image of the osd, it looks like electric interference, and then fades to just interference. I have tried changing composite cables, I've tried svideo cables and even changing inputs in my tv....
          26 April 2004, 14:34 Monday
        • bborzell
          Rsp-1066 Osd
          by bborzell
          I am running component video to my projector (Dish Network and Xbox) and a HDMI cable from the OPPO BDP-83 to the projector. I have an S-video cable routed in the wall between the RSP-1066 and the projector but have never used it.
          Here's a quote from the Rotel manual that has kept me...
          02 May 2009, 16:39 Saturday
        • jprafter
          Any tricks to get C2 OSD for HDMI Sources???
          by jprafter
          I'm very happy with my Parasound setup though it looks like my C2 will never support HDMI fully. I use a combination of my C2 and TV for video switching along with the MX-700 macros. So I really have no need for a Parasound HDMI switch only device, since it will do nothing to help with OSD.
          13 October 2006, 07:49 Friday
        • Peterc4c
          Composite Video out with OSD.
          by Peterc4c
          When I use my composite video out with OSD. The OSD flickers on my Infocus 7205. However, the picture is fine. Are anyone also having problems with this??
          Peter
          06 December 2004, 12:39 Monday
