Does anyone else have trouble connecting speaker tips through the terminals on their receiver?
I have some thick Monster THX Cable that I run to my two fronts. The cable tips have a flaired gold connection tip. It's thicker than a flex pin.
The tips fit into the back of my B&W's no problem- but they do not fit all that snug on the HK receiver.
The screw bar- for the plastic cap used to tighten the connection- is right in the center- which leaves little room for the tip to sit.
I crammed them in and screwed the plastic cap as tight as it would go and I was still able to pull the connection out.
It just does not want to sit in there.
A thinner flex pin might work better- but the cable is pre-built with this thick tip.
Anyone have this happen?
