This is from the B&W thread regarding choosing the HTM3S and HTM4S for HT purpose. I am starting this over here in case there are other HT experts who uses either of these centre speakers who can advise and in case the Moderator thinks I have broken the rules in the B&W thread.
For HTM3S or HTM4S owners using for HT (not multi-channel audio), do you set the AV processor to Large or Small for your HTM3S?
The following is an excerpt from an interview with Guy Kuo from AVIA DVD advising setting to Small and let the subwoofers handle the LFE.
"The setting of speaker size and bass management tremendously affects how bass is handled for each channel. Speakers set to "small" have their low bass routed to the bass output channel (s) which can be either just the subwoofer , the "large" speakers or some combination of subwoofer and large speaker depending on how the receiver is set up.
We highly recommend setting all speakers to "small" because the very very low bass content down to the 20's Hz simply is not as well reproduced by most main speakers as a dedicated sub. Even if one has powered subs inside the main speakers, room placement of those speakers is rarely if ever the best location for bass reproduction. By setting the speakers to "small" you give each speaker a chance to excel in what they do best.
If a speaker is set to "large" its low bass content will not be sent to the subwoofer output. Remember this!"
If this is the case, then would it matter whether it is an HTM3S or HTM4S since anything below 80hz gets passed through to the subwoofer under HT DTS Surround or Dolby Digital Surround?
I agree that it would matter if using for multi-channel audio but I am not keen on multi-channel audio in my case.
Any ideas on this?
Any ideas on this?
: Many people have called me mad for having a set of Mains with Subwoofers built in along with a Subwoofer! :P
