Pro-logic IIx steering problems.
  • Akuza
    Hey all, wondering if you could help me with a little problem?
    I have a Denon 1705. When I use it in DPL2X the right and left stereo channels randomly are directed to the rear speakers (5.1 setup) leaving the front stereo channels naked. I have noticed it with videogames and TV. Haven't tried VHS...and I don't know if I ever will...
    Is this a problem inherent with dpl2x?
    Any help/suggestions/whatever would be groovy. :T
  • Azeke
    • Mar 2003
    • 2123
    Akuza,
    I don't believe so.
    Do you have your receiver set for 7.1, in the menu (esp., center backs)?
    Arman
    • Akuza
      It is set for 5.1. It is in PLII mode really, not PLIIx.
      • Aussie Geoff
        • Oct 2003
        • 1914
        Akuza,
        Check your Settings for Panarama and Dimension for Dolby Prologic IIx - I
        PANORAMA: The Panorama option extends the front stereo image to include the surround speakers for a dramatic “wraparound” effect. The options are OFF or ON.
        DIMENSION: The Dimension option allows you to gradually adjust the soundfield towards the front or towards the rear. There are seven incremental settings from 0 to 6. A setting of 0 shifts the soundfield towards
        the rear for maximum surround effect. A setting of 6 shifts the soundfield to
        the front for minimum surround effect. The default setting of 3 provides a “neutral” balance between the two extremes.
        So if you have Panarama = On and Dimension =0 you will get the effect you are describine - Have Panarama on and Dimension 3 and you wll get a better result.
        Regards
        Geoff
