Help...save me from the web of W.....
  • saurabh
    • 329
    Okay, this is about interference from the various parts of the HTS, primarily the web of wires. The problem that I see is a low "Hum noise" in the TV speakers if the DVD player (which is right below the TV, its a HTIB) is ON/in standby mode. The moment I pull the plug for the DVD player, the "hum" from the TV is gone. So I figured its interference!!!, now I am looking at four types of wires around the system.
    1) Electrical
    2) Speaker Cables
    3) Cable TV wire
    4) FM Antennae wire
    As usual the wires are longer than required and I have used a tie to manage them and keep them bundled. Also except for the Cable TV wire I cannot trim the other wires, since cos of being a HTIB, the wires have moulded connectors on both ends, which I dont want to fiddle with. I know that "Idealy" the wires if crossing each other should cross as right angles, but its not possible to do that(we are not loooking at two wires here but a lot of them) and I am looking to find a more practical and effective solution than the lab calculations and theory involved.
    Has anyone faced similar situation........has a solution ?????...heeeelp
    Need is the mother of all Inventions.....I am needy
    • 16101
    Not "interference"... ground loop injected noise, especially as many inexpensive DVD players now use SMPS power supplies. The overall ground loop, also, may be through the DVD player and your cable input- see if you disconnect either one and the noise goes away. If that's the case, you're going to need a cable RF isolation transformer.
    ~Jon
    • ekkoville
      • 392
      I agree with Jon, this has been a subject in several threads and I have the same problem that I found to be introduced from the TV cable. I checked the grounding and finaly used two 75-300 Ohm converters rigged together to rid the noise. Jensen makes a great RF transformer for about $50, and that will work nicely, so long as it's your cable that is the problem.
      Erik
      ____________________
      Erik
      Just another case of the man trying to keep us down! :B
      • saurabh
        • 329
        I guess it was interference only, since i seperated my power and signal/sound cables and have kept some distance between them now and the hum is gone. BTW both my TV and DVD use 2 pin plugs so Ground loop problems seems unlikely.
        • beden1
          Classe Amps - Possible Case for Speaker Wires
          by beden1
          Possible case that speaker wires and balanced versus RCA connections make a difference that I had not considered.
          This hobby is complex in nature, and it's interesting that one gets to continue learning along the way through experimentation.
          Case in point: I have owned...
          20 October 2008, 12:24 Monday
          Exploring Common DIY Terminology - Noise
          by technodanvan
          Noise
          In the context of loudspeaker measurements made during the design process, noise refers to any unwanted electrical or acoustic signals that can interfere with the accuracy of the measurement. Noise can be introduced through various sources, and it can affect the reliability and precision of the measurements, making it essential to minimize its impact for accurate loudspeaker evaluation. Sources of noise include:
          • Background Acoustic Noise: During loudspeaker measurements, ambient
          21 July 2023, 18:08 Friday
        • Barley
          LCD Projector interference??
          by Barley
          Hello All,
          I have owned a Sharp LCD projector for almost ywo years now and it has been installed in two homes as my home theater. In the first home everthing worked perfect. When I moved I brought the projector with me and installed it the same way with the power cord running up into...
          01 August 2005, 11:59 Monday
        • AngelEyes
          HTPC and Rotel RSP1068 Interference / Noise
          by AngelEyes
          Hey chaps, I hope you can help.
          I finally switched from digital coaxial to 7.1 analogue connections between my HTPC and Processor to take advantage of the new sound formats.
          Unfortunately the upgrade has introduced a nasty buzzing sound through the speakers. It does not...
          24 April 2007, 05:21 Tuesday
          Cheap tweak series, article I: Cable management, the nemisis of home theater?
          by Lex
          Wiring is a difficult problem to solve. Especially with racks that are more open than closed in. Mine did look like the back side of a Nasa control center before finally getting back there and straightening it out. The more gear you have, the more difficult the task of course.
          Try...
          27 December 2003, 22:23 Saturday
