Power needs analysis...
  • ajpoe
    • 439
    What do you guys think about this? My Studio 60s have a sensitivity of 91.
    CHART:
    Watt(s)...SPL(dB)
    1.........91 (Studio 60s rating)
    2.........94
    4.........97
    8.........100
    16........103
    32........106 (Dolby Digital Home Theater SPL Level)
    64........109
    128.......112
    Based on this chart, I only need 32 pure watts to achieve the DD standard, which in a home environment is quite loud and most people don't even listen at these levels. 64 watts gives you some cushion just in case... I am using a Rotel RMB-1075 which is rated at 125 watts per channel. I'm guessing it's safe to say that my amp is never clipping and I don't have a need to upgrade as long as I keep my 60s?
    I don't plan on changing anything. I love my setup. I just thought I would post this to get a conversation going and see what others thought. I got this information from the guy who posted the different receiver power ratings and found it to be interesting.
    AJ
    P.S. - I know the power ratings for the various receivers has been posted before, but I had never really calculated it out like this so sorry if this is a repost as well. For anyone who is interested in the power ratings site, here's the address.
    AJPoe - - Growing old is inevitable, growing up is optional!
    • 16169
    I have found many mainstream manufacturer's data for efficiency to be anywhere from slightly off to outright lies. Descrepencies of up to 4-6 dB.
    The Studio 60's are a floor standing two way in what is referred to as a 2.5 configuration, as the seond woofer is rolled out relatively low and provides baffle step compensation of the bottom end. Good 7's that will deliver low end extension in a larger cabinet like this typically have a nominal sensitivity around 87-88 dB. The second driver essentially provides the additional output needed in the conversion from 2pi space to 4 pi space because of the baffle size (baffle step compensation). Considering the "Anechoic" rating from Paradigm is 88 dB, that's probably an "honest" FTC style rating. .
    Recalculate based on that, not the more optimistic 91 dB rating.
    Note, 3 dB = 2X the amplifier power.
    ~Jon
    • ajpoe
      • 439
      Thanks John, I was hoping one of you smart guys would chime in. If I recalculate at the rating of 88, then I'd need 64 pure watts to achieve the DD standard instead of 32 since it starts at 3 db less. Since the Rotel conservatively provides 120 watts x 5, I'd say its safe to say that I have plenty of power. I calibrated my system and I'd have to have the volume around 82 on my 1068 to be at the directors intended levels. This is extremely loud and I generally watch a movie around 70-72 if its DTS or 72-75 for DD (the later if no girls are present... why don't chicks like loud movies? LOL)
      • hidefdvd
        • 60
        Try this db calculator. It should give you an idea how many watts your using to reach reference level. The other 3 speakers in a 5.1 setup add to the overall db level.
          • 16169
          Don't forget there are peak to average issues- you may playback at an average SPL in the mid 70's to 80's, but short term peaks can be 20 dB higher. Still, I agree that the Rotel your should be up to the job just fine.
          • ajpoe
            • 439
            John, I was under the impression that the rating of 106 db for DD was at the peaks and that normal dialogue and more quiet scenes would be much less. So as long as my power/sensitivity calculations are fine to those peaks at 106 db, everything should be fine. Is this a correct assumption? According to the charts, I only need 64 pure watts to achieve this, but I have some cushion just in case.
              • 16169
              That should be a correct assumption. Of course, some peaks are longer than others... and the unfortunate thing that comes out is that multi-channel receiver power ratings have a lot of gamesmanship involved- often power rating is quoted mainly for 2 channels driven out of 6 or 8 (5.1, 7.1), then somewhere in fine print they may have a rating with all channels driven, in which case the power supply is working very hard, there's a lot of voltage ripple on the power supply rails, and the sound quality suffers. For this reason alone I would recommend having a 3 dB power margin over calculated results, unless using seperates with clearly defined ratings for all channels driven simultaneously.
              But I'm a bit of a stickler and luddite....
              • AndrewM
                • Oct 2000
                • 447
                Oh just go pick up a nice pair of 600W monoblocks already
                Andrew
                High effeciency and high power make a nice combo
                • ajpoe
                  • 439
                  Excellent! I have a 3 db margin based on my calculations (or very close) and Rotel is rated all channels driven at 8 ohms 20 hz - 20 khz. :T
                  Andrew, 600 watt monoblocks would be nice... if you'd like to donate a few, i'd be more than happy to keep them warm for you! :B
                  • Kingdaddy
                    • Jan 2004
                    • 355
                    That chart would be of use only for an active system where the drivers are directly coupled to the amps output. Passive crossovers dissipate as much as 80% of the input power into heat, so I've read. So it depends on how many passive components and how much series resistance is in the crossover.
                    My Center Channel Project
                      ratings board at it again :(
                      by Andrew Pratt
                      No sex please, we're Yanks
                      Censors don't allow adults to enjoy doing it
                      By LOUIS B. HOBSON -- Calgary Sun
                      HOLLYWOOD -- Urgent message for James Bond.
                      If you come to America, you'll be allowed to have sex but don't you dare enjoy it.
                      That's the...
                      30 November 2002, 19:15 Saturday
                    • bleeding ears
                      Why do speakers have a max watt rating
                      by bleeding ears
                      Whilst pondering which amplifier and which output wattage would best suit my speakers, I became a little confused about the whole amp/speaker wattage compatibility issue.
                      Eg , if speakers can handle wattages well above the manufacturers specified maximum rating, why do they specify...
                      08 February 2006, 08:49 Wednesday
                    • chinets
                      Please Jitter rating on both Rotel RDV-1060 and the RCD-1072!!!!
                      by chinets
                      Hi Everyone,
                      Can you please give me the Jitter Ratings of both the Rotel RDV-1060 and the Rotel RCD-1072??? :W
                      Are both there Jitter ratings high or low???? 8O
                      The Marantz DV-9600 has a Low rating of 300ps for example so how would you compare both with the Marantz???
                      Thanks...
                      17 May 2006, 10:11 Wednesday
                    • mike c
                      RB1050 power ratings
                      by mike c
                      in the online brochure it states that the RB1050 has 50wpc
                      in the online manual it states 70wpc
                      both at 8 ohms.
                      which one is it?
                      where do you guys get the ratings for 4ohms for all the rotel amps?
                      what rating does the 1050 have on 4 ohms?
                      does it mean...
                      06 April 2006, 18:35 Thursday
                    • macvidguy
                      More speaker help - Ohms and Watts whats?
                      by macvidguy
                      Thanks for all the Bose bashing you provided. With regard to speakers and assuming I win the battle for Denon 2805 which is 7X100 and has ratings for 6 and 8 Ohms (100watts). If I understand right (my conservative thinking) I need to get speakers that support at least 100 watts right? If they are...
                      17 December 2004, 16:22 Friday
