hey...
I am in the process of converting from an audiofile system to a home theater setup and i was looking for any advice!
My audio system was/is:
Bryston 4B amp
Classe preamp
Dahlquist DQ 20 speakers.
i no longer have the amp/preamp, so basically im working with my dahlquist speakers
I have been considering buying a Rotel 1056 receiver, and running the dahlquist and my plasma thru that setup until i find either speakers to match the dahlquist, or just get entirely new speakers
advice?
should i just scrap my speakers and get a whole new setup?
should i try and incorporate my speakers into a new setup since i love them,?
any advice is appreciated, also would love opinions about speakers, receivers, etc
Bryston 4B amp
Classe preamp
advice?
You might consider keeping the D's for a seperate 2-channel system and just get new gear for HT with Dahl being out of business...(I had no idea either Doug!?) You could try the used market to find matching speakers as well but may have limited sucess depending on availability etc.
