Does anybody have any sugestion for setting up the satellite sepakers for an effictive surround sound. The room is about 20 * 12. Any suggestion would be helpful.
Speaker Set up Help
More info about your room layout would probably be more helpful in yielding good suggestions. Couches? How many...where... etc. Is the tv in a corner? Along a wall? That kind of general stuff- Bottom
Check Out Similar Threads In This Forum
you can also see few live threads in this forum, probably they will help you understand most speaker layout scenarios and the doubts you can ask here.Need is the mother of all Inventions.....I am needy- Bottom
by SpadenationSorry in advance if this page doesnt fully load on your computer. Its got way too many pictures on it!
hi there!! finally got a new pre built house and have some ideas for my living room that I have lots of questions about. So I made this quick layout for easy reference. I’ve been...-
Channel: Spaced Out
by george_kWith the coming delivery of my 703's, I though that this may be a good time to change (maybe optimize) my room layout. I haven't tried this in the past because I was too lazy to move the furniture, wall-mounted surrounds, cable wire, etc...
Attached is an image showing my current layout...-
Channel: Club B & W Speakers
by Rock DogWell, I purchased some new audio gear. The unit has CD, DTS Audio, DVD-Audio (including a full 5.1 discrete channels of audio) and XM Sat Radio. Plus a full Blue Tooth setup.
The best part about the new gear is the packaging and design/layout. I think it's awesome. Remember beauty is...-
Channel: Audio Hideout
by saurabhhi,
After discussing my previous room(if you have seen my previous thread) layout (which was really bad) in this forum, I was able to convince the "decor police" to vacate one of the rooms for the HTS(layout is attchd) and we will shift the TV/HTS there. Now I want to mount...-
by stidrvrWell Im planning the layout of my dedicated theatre room in the basement. So far as it stands it will be 12w x 23dx 8h. The spot that I decided on offers me the max amount of size, without obstructions. Seating will probally be atleast for 4 people so most likely two couches. The rear couch being on...-
Channel: Spaced Out
- Loading...
- No more items.
