Need help with Zenith dvb318 settings!
  • Rob W.
    • 9
    I got this Zenith 318 and tried hooking it up to my Sony Wega 36" crt tv but my Sony won't accept progressive scan signals. I want to use component outs from the dvd because of the better picture but I don't know how to change the player settings back to interlace. I tried contacting Zenith and the tech guy said I couldn't and had to use the s-video, but some other person at Zenith told me via email to play a dvd, press stop, remove the dvd and hold stop for 5 seconds and the player would reset to normal output mode. I tried that and it's still in progressive scan mode. Please help me if anyone knows how to do this.
    Rob
  • rick c
    • 430
    if you dont have component on your tv you have to use the svideo.
    • Rob W.
      • 9
      The Sony does have it
      Rick, my sony does have the component inputs. It just doesn't accept p-scan. What I'm trying to do is get my Zenith to output reg. interlace through the component outs.
      Thanks.
      • number17
        • 80
        Rob, does your Sony WEGA takes HD signal? I'd assume it does because most (if not all) people buy this DVD player for its ability to upconvert DVD signal to HD signal
        The component output of the Zenith 318 will only output HD signal in the form of 480p, 720p and 1080i.
        If by saying 'my tv doesn't take progressive signal' you mean it will not take 480p or 720p, you can go with 1080i interlaced HD signal. Just press the 'upconvert' button on the front of your DVD player (it's not available on your remote!) when you are not playing any DVD.
        But if your WEGA TV doesn't take any HD signal at all then you're out of luck. You can connect via S-Video but then it defeat the purpose of the Zenith 318, which is to upconvert to HD.
          • 16104
          The Zenith does not output interlaced video on component. The component outputs in the Zenith come after the Faroudja DCDi chip, and only progressive scan outputs are available. You'll have to use the S-Video outputs with your Sony.
          The main thing the Zenith does well is upscaling to 1080i, including with video based sources which give many DVD players problems. It's not really a good match to your Sony 36"; you should look for an inexpensive interlaced output player - preferrably one free of the CUE bug (Chroma Upscaling Error) so that when you do have a progressive set some day, you'll get clean color reproduction. Check the Benchmark tests for DVD players at Secrets of Home Theatre and High Fidelity.
          ~Jon
          • Rob W.
            • 9
            Thanks guys for the info. I appreciate it.
            Rob
            • sixwest
              Zenith using DVI
              I recently had to flash back to the DVI version of the 318 using the firmware upgrades at this link:
              I can't get a picture using my HDMI now and noticed that the supplied cable was a straight DVI - DVI connection.
              Do I need to get a DVI/HDMI adapter for this cable in order to use the HDMI port on my TV?
              Or am I missing another procedure somewhere?
              Thanks!
              • nfsmith
                Zenith DVB318 Using DVI
                There was an insert with my DVB318 Owners' Manual. It states that with DVI, you should turn the TV on FIRST, before turning on the DVB318.
                Perhaps you missed that, and hopefully it will solve your problem... otherwise, good luck!
                -nfsmith
                Thanks!
                • Uncle Clive
                  Former Moderator
                  • Jan 2002
                  • 919
                  Rob
                  ROB........... what you could do is take the unit back to the store where you bought it and ask them to hook it up to a unit with HD inputs, this way you will be able to see the menu and change the settings. NOTE: - If your remote has an I/P button on it that would be the one to use to switch back to interlace (before taking it back though).
                  CLIVE
