wich front speakers with rotel RSx1056
  • calli43
    • 13
    HI there,
    I am looking for new frontspeakers for Rotel RSX1056.
    Up to 2500$ a pair. The speakers I have in mind are
    B&W CM4 1400 euro
    B&W 704 2200 euro
    Dynaudio audience 72 about 1800 euro
    Which off this speakers do you recommmend and why.
    Other suggestions are welcome.
    Ofcourse I am going to listen as well at my dealers shop as at home.
    Further I am using a canton CD50 as center and Keff eggs as rear.
    Center will be updated in not too long time.
    Looking forward to your advice,
    Karel Unij
    Holland
  • BlazeMaster
    • 644
    what will you be using the speakers for mainly? HT, stereo, or multichannel music? Tell us a little bit more about
    • Jraducha
      • 51
      I would say go with the Dynaudios... They are a great product. Sound excellent. The sound is very natural and smooth. Good imaging speaker and makes a wide sound stage..
      • calli43
        • 13
        I will use the speakers for Stereo 50% HT 25% Multichannel music 25%.
        Further I like dynamic speakers.
        karel
          Karel, I have to agree with Jason. Go with the Dynaudios. Amazing sound, plus you have a rather nice upgrade path.
          • rick c
            • 430
            I would'nt use dynaudio with the 1056 unless you add an amp.I was in the same boat a cpl of months ago cause wanted the dyns.I called rotel and they said definatly dont use 4ohm dyns w/rotel rsx1056 w/o an amp.I didnt have the budget for the spkrs and an amp so i guess i settled and got B&W 603s3 setup instead.Regardless i'm very happy with the B&W setup.
            • Jraducha
              • 51
              Just a little FYI. But Dynaudio uses many different amps when they are testing their speakers and have a close relationship with the guys at rotel. The rotel is a great amp if you are running 4ohm speakers.
              If you are really nervous about running the 4ohm speakers on the rotel and like the sound of the dyns maybe you should look in to the Audience 122s. They are 6ohms.
              • calli43
                • 13
                Jraducha,
                I am not nervous about running 4ohm speakers, because the MB-Quart QLC604 that I use now are also 4ohm. I asked Rotel once if connecting 4ohm speakers could give any problems. No they answered but they were preffering 8ohm.
                greetings karel
                • Jraducha
                  • 51
                  How do you like the sound of the MB-Quarts? I sell their car line and find them to be really bright.... I dont know anyone in the phx area that sells them and i would really like to get a listen...
                  • rick c
                    • 430
                    I originally was set on getting some dynaudios to add to my rotel rsx1056.Just to make sure i wouldnt have a problem w/4ohm i called rotel and was told do not do it.I then got the next on my list which was the 603s3.Needless to say i am now flustered after hearing you guys that i could of gotten the dyns w/o a problem.
                    • Jraducha
                      • 51
                      Sorry to hear that you dont get to enjoy the dyns on a daily basis. This forum is really a great tool to get advise and get the insite on new products and things that work with each other.... You still made a good choice with the 603s.
                      • rick c
                        • 430
                        yeah,i think so too.Just a little dissapointed that i didnt get my first choice because of what i was advised by rotel.
                        • Foxman
                          • Jan 2003
                          • 434
                          I would audition as many differant speakers as you are able to with the Rotel. B&W certainly seems like a popular combination as does Klipsch. Paradigm and Kef are both nice sounding speakers to me, but you might not like them.
                          IMO
                          My Movies
                          Bad Pics of my system
                          • calli43
                            • 13
                            Today I listened 4 pair off speakers.
                            B&W cm4 To thin on my rotel, bass was almost not there. (on a camebridge receiver it sounded very good)
                            B&W 704 Sound was good but much to laid-back
                            Dynaudio audience 72 on rotel to laid back not dynamick enough for me.
                            B&W 703 this speakers enjoyed me very much. Good dynamics and the sound came off from the speakers. Overall sound very good i.m.o. But my goodness 3000euro a pair is quite a lot off money.
                            In some time my dealer will get a pair 2nd hand B&W 804 matrix speakers. Maybe that is the right the speaker for me.
                            In the meantime I will go on with the MB-quarts.
                            And comparing to what I heard today they are not that bad afterall.
                            Greetings Karel,
                            • calli43
                              by calli43
                              HI there,
                              B&W CM4 1400 euro
                              B&W 704 2200 euro
                              Which off this speakers do you recommmend and...
                              17 January 2005, 10:32 Monday
                            • calli43
                              whats a normal temperature for RSX1056
                              by calli43
                              HI,
                              When I was cleaning the upside off my receiver I noticed that it was pretty warm. I think about 45 degrees Celcius. Is this a normal temperature or should i be concerned.
                              greetings karel
                              11 August 2005, 10:42 Thursday
                            • calli43
                              Attaching DVD recorder to RSX1056
                              by calli43
                              Yesterday i bought A HD DVD recorder wich can also record audio on HD.
                              Wich audio output off my rotel RS1056 can i use for this.
                              Normally i would pick tapeout but here i attached an headphone amp.
                              Now i think the only output i could use for this is zone2 out....
                              21 January 2006, 13:04 Saturday
                            • rick c
                              rotel rsx1056 w/4 ohm speakers;misconception
                              by rick c
                              I always thought that the rsx1056 should not be used with 4ohm speakers.Atleast that's what rotel told me a while back when i was inquiring about dynaudio speakers,so i ended up with B&W 603s3's/lcr600(really liked them anyway).Well i have upgraded my speakers to a System Audio setup(sa1750/sa720av/sa505's)these...
                              03 May 2007, 21:41 Thursday
                            • csuzor
                              Preamp choices: RSP1068 or RSX1056 or AVR3805?
                              by csuzor
                              Is the better choice the RSP1068 or RSX1056 for pre-amp duty?
                              I will add the RMB1066 (in bi-amp mode) or the RMB1075.
                              I am upgrading from a denon1804 to drive B&W700series in 5channels only (no sub yet)
                              Being budget limited, choosing the RSX1056 allows me to...
                              28 February 2005, 05:27 Monday
