Turntable Choices
  • rdram
    • 98
    Turntable Choices
    Hey all,
    In January 2013, I bought a Pro-ject Debut III to see if I wanted to get back into vinyl. The answer was yes, and it's time to upgrade. Couple things with the Debut III...has an 11" platter and a $50 cartridge. I think I might be missing something. My three options for an upgrade now are a Music Hall MMF-7.3, a Rega Planar 6, or a Mobile Fidelity Ultradeck. I would go with MM cartridge, so Rega and Mofi both at $2000.00. Music Hall with Ortofon Bronze at $1595. Since we live on line, I can't go to see any of these.
    Opinions? Thanks.
    Rich
    sorry, Rich.... i just saw this....
    ...i am not getting notifications of posts for some reason.... need to fix that..!
    let me get back to you after i have time to more thoroughly digest your question & options....
    regards,
    bill
    • rdram
      • 98
      Hey Bill,
      Thanks for the response. No hurry...just considering options. TT is running thru a Mac C48 preamp, using the phono stage built into that. Preamp does have MC input, but I've never owned anything with a MC cartridge. I suppose that could be an option with the MoFi or Rega TT's.
      Rich
        Originally posted by rdram
        Hey Bill,
        Rich
        hi Rich!
        valuable info there, answered a lot questions i was going to ask....
        what is your budget?
        do you prefer detail or smoothness?
        flat response or leaning toward forward highs or accentuated bass?
        • rdram
          • 98
          Bill,
          Thanks for responding. To answer your questions...
          Budget: $1500-$2000. Budget is a little flexible, as this will be my last TT purchase. Rega Planar 6 with Ania MC cartridge is $2200.00. I could do that, but if Music Hall MMF-7.3 is $1595.00, then how do I justify an extra $$600 for Rega?
          Do I prefer detail or smoothness... not sure how to answer that. Shooting from the hip... detail.
          Flat response or leaning toward forward highs or accentuated bass? Again...not sure how to answer that. It has been my opinion that a component should not have any influence....meaning a TT should reproduce what's on the vinyl without adding anything. Having said that, if I had one critique of my current TT, it would be a lacking at both ends... no bottom end and no top end. A function of a $45 cartridge? Maybe...so I guess I'd pick forward highs, accentuated bass.
          Bottom line, this is probably a question no one can answer. I did notice that your Avatar looks like a Music Hall TT. and if so, and you've had good luck with that TT, then that's what I'm looking for. Opinions from an owner... Thanks.
          Rich
            well, Rich, once again i am late to the game..... V late...
            so sorry...
            yes, i have a MMF-7 with a Pro-Ject Speed Box & an AT150MLX Cartridge.
            i am V pleased with its performance.
            the Music Hall will most likely be the 'smoother' of the two, as the rega is known for its speed, as in the acronym PRaT, which stands for pace,rhythm and speed.
            • Industrial
              Proud new owner of a Rega P5 TT
              by Industrial
              Just went out and demoed the Rega P5 Turntable. Loved the sound so much I had them order one for me. Should be brought here and setup by next weekend. Got the cherry wood deck. Also got a "Exact" cartridge (the yellow rega one) to go along with it. I tried the one up from that (the blue one)...
              23 January 2010, 16:26 Saturday
            • kiko
              Looking for new cartridge + stylus - Help appreciated
              by kiko
              Hi everyone
              I am shopping for a new cartridge + stylus for my turntable, or so I think. I currently own an entry-level Stanton T50x turntable bought 5 years ago when I wasn't too sure going back to vinyl would be as exciting and feasible as it is now. I run that Stanton through a Yamaha...
              11 September 2010, 09:31 Saturday
            • JazzCrimes
              Rega Mira and B&W speakers
              by JazzCrimes
              I'm looking for an integrated amp to pair with my B&W CM7s. I've heard the Mira with both Rega and Totem speakers, however, I've been unable to find a dealer that carries the Mira and B&W speakers. The other (safer) option is a Rotel 1520, which I did demo with the CM7s with good results. ...
              17 July 2010, 10:16 Saturday
            • Susan
              Replacement Phono Cartridge/Stylus
              by Susan
              Can any of you recommend a a good cartridge/stylus discounter? I need to replace the stylus on my Sony direct-drive (PSFL-72 II) but the Shure site doesn't recommend a replacement model. I'd love to buy just a replacement stylus, but realize this may not be possible as the cartridge (N110HE Shure) is...
              01 February 2001, 03:44 Thursday
            • migliore
              Rega Planet 2000?
              by migliore
              I see Rega has release a new planet. Anyone heard/seen one? Does Rega have a website yet? I don't have much information on it. I've been quite happy w/ my 1998 Planet.
              I think they also re-did the Jupiter/IO into a one-box solution - is this true?
              Rob ...
              08 December 2000, 14:54 Friday
