A better cork mat or just getting more of your $
    • 27461
    Opinions about this cork mat bunk or truth? about their claims of better with less record contact? I'm not sold that it does anything, except make your less than 180 G records more likely to float around. Opinions?
    • 5673
    things like this are V device dependent.
    they work better on some tt's & not so much on others.
    the principle is to isolate & reduce the transmission of minute vibrations that find their way to the cartridge & effect the character of the audible signal.
    HERE is another popular one.
    remember that changing the mat thickness requires adjusting your VTA (vertical tracking angle).
    this is a good read, the LINK provided by the good folks at Vinyl Assylum.
    section #9 deals specifically with VTA
      • 27461
      Right. Thanks Bill for the input. I think I will opt, no on this one. I think it might make more difference on a table with a less solid platform than I have (platen) As thick as my acrylic base is, and as solid as the bearing assembly is, there's no movement except circling the spindle, within reason. So I think it's safe to say i am in pretty good shape on the felt I have. I am not a huge fan of felt, as I think it can be a conductor of static electricity, and that is our enemy. I could be wrong, but I always thought that possible with felt.
      thanks,
      • vneal
        • Jan 2017
        • 9
        I considered this mat but the label portion of the cork should be indented not raised as this design has. So I XXX this model
        B&W CM10,
        B&W CM Centre 2S2
        B&W CM S2
        JL Audio F110 V2
        McIntosh MC207
        Sony HAP Z1 ES
        OPPO 105D
        Emotiva UMC 200
        Pro-JEct SE 5.1
        PAarasound Phono Pre
        Furman Elite 15 P
        Kimber 8TC -Heros IC
