Michelle Prisma parts...
  • fastharley
    • Oct 2014
    I am attempting to restore a Michelle Prisma TT.The original support legs were totally worn out so I replaced with a handmade,hand oiled wooden base with oil filled feet.I found a SME type 3 arm and had it rewired and fitted.Currently running a Grado gold cartridge (soon to be upgraded).The problem is that when i was putting it all back together I somehow managed to break one of the speed adjuster controls...(thankfully it was not the one that controls the 33 1/3 setting).Now I need to find the replacement parts...and so far no luck.) The TT works perfectly otherwise and sounds great with my Marantz K1 Pearl and Klipsch RF 7 towers.
    So you have one of the early Michell tables similar to the Transcriptor model made famous in the movie ‘A Clockwork Orange’ ……… & it is on a wooden plinth!
    http://www.michell-engineering.co.uk/history/
    That is ‘way cool’!
    I would love to see a photo.
    If you are still trying to find parts I suggest you try over at the Vinyl Asylum forum.
    If anyone knows where to find parts for it, they most likely will be there.
