Speakers
  • MrWizerd
    • 5
    Speakers
    Hello all, I am looking into buying speakers. I have a yamaha rx-v1400 for my home theater. I am looking for clean fast responsive sound, that is at least a little above the 20k range, and some ok to descent lows.
    I have settled on the sunfire True Subwoofer EQ Signature for my sub. I have looked at the Monitor speaker line, and the mid/high end silver series sounds great, and the center channel is nearly indistinguishable from the gold series. The gold series seem to run around 2k. The reason for my delema is that i was thinking of getting a velodyne sub, but it seems that the sunfire is cheaper and a lot better than the velodyne series there 10" only reproduces 18hz and the sunfire is 16hz So i dont need increadible low for my fronts just enough to cross over nicely between the two sets and the sub. I dont know that my reciver has the power to drive some of the ribons like martin logan, or the magnipans wich have a VERY attractive price. My reciver only goes down to 6ohm.
    So I am trying to tend more to the higher end equiptment so that I am able to slowly upgrade slowly but the speakers are itragual in this. eventually I want to switch out to seperate preamp amp and what not for higher power when i have the roomsize for it.
    Any help you can offer for a great speaker set from 1500-2000 that will work with what i have, or will the monitor's i am looking at do the gob well?
  • Azeke
    • Mar 2003
    • 2123
    Mr Wizard,
    This would depend on your personal test.
    However, I have the following generic speaker recommendations, which may fit your price range (not in any specific order):
    1) Mirage
    2) Energy
    3) Def Techs
    4) B&W's
    5) Martin Logans
    I sure other members will provide further input.
    Just my quick thoughts,
    Azeke
    • Shane Martin
      • 2852
      A lesser known brand that you should look at is http://www.phasetech.com
      Take a peek at their Velocity series. I bought a 7 channel setup for $1800 with tax. A 5.1 setup would run you around $1400. VERY highly recommended.
      RE Martin Logans: You will have to go used probably. The cheapest new ML runs $2k and they are REALLY power hungry.
      • theMaximus
        • 179
        One thing to keep in mind is that Martin Logans are generally very tricky to set up. Electrostatic speakers can do wonders but placement has to be just right. If you have a lot of constraints (weird shaped room, a lot of furniture, etc...) in your listening room, you may have trouble setting it up.
        You may also want to consider KEF Q7 speakers. They are in your price range and very very nice speakers.
        Whatever you decide to buy, just stay clear of Bose. :T
        Victory Shall Be Mine!!! :heh:
        • jimmyp58
          • 1449
          What are your listening tendencies (music vs. HT)?
          jpiscitello@ameritech.net
            Heh, yeah. And newer KLHs too. They're so bad, they'll make you go :thud:
            • Britchie
              • Nov 2003
              • 45
              I just went through an extended audition and chose B&W 804's. The 604's are very nice too and were close in sound but half the price. Second place however went to Paradigm 100v3 which can be had for around 2000 a pair.
              Good luck. let us know what you choose.
                Twin Moderator Emeritus
                • 16706
                Originally posted by Azeke
                Mr Wizard,
                1) Mirage
                2) Energy
                3) Def Techs
                4) B&W's
                5) Martin Logans
                Azeke
                I just want to add Paradigm, PSB, Kef, Vienna Acoustics and Totem to that list
                • Drew_W
                  • Dec 2003
                  • 75
                  The Yamaha will drive 4ohm speakers without major issue...but it won't do the best job doing it...Yamaha receivers have severe power deficiencies.
                  The reason Martin Logans are so hard to drive is because their impedance drops down to around 1ohm...many power supplies will crap out when they try to juice out this much current.
                  If I were you, I'd take some of that budget, and get a used 5-channel amp. A Rotel RMB-1075 won't cost you much more than $700 and will power most any speaker with relative (to your Yamaha) ease. It would also make pretty much any speaker sound better than with the Yamaha...
                  • MrWizerd
                    • 5
                    Ok, my speaker allowance went up today when i got a phone call at 4:30. I listen to a lot of classical music and opra. I also am a home theater fanatic, though only a new fanatic. I was thinking of getting a 7.1 preamp and start buying martin logans, or something so that later if i choose to go to something that requires more power i can juice them also. I dont know if i can setup the presence fronts (9.1) if i do get a seperate amp for the 7.1 preamp outs.
                    I have listend to the Engergy, and i have looked into the B&W and Martin Logans so far. Back to the research, i was looking at Thiel they go a minimum of 3ohm, and i know that my unit will do two but i don't know how long it can hang out there. I apreciate the leads, soo..... back to the drawing board, or should i say the reading board, i have dozens of pdf files laying about. A lot of it is mute to because i wont have heard any of them. So i will be buying def, and ... well blind on the projector also. So i am holding on to the recomendation of the wiser peoples of the world THANKS AGAIN!
                    • jimmyp58
                      • 1449
                      You will certainly enjoy the Defs
                      • Bam!
                        • Jan 2004
                        • 2458
                        .....I have to add in....have you listened to Pro Acs......like the Studio 100's let us say ?
                        Got a nice rack to show me ?
                          • 16706
                          I think he meant he will be buying without listening or "def" :lol: (Which BTW I don't recommend if at all possible you should always listen/view/try out gear before buying.)
                          • jimmyp58
                            • 1449
                            Thanks for clarifying that Jason; my bad!
                            • Burke Strickland
                              • Sep 2001
                              • 3159
                              Since you listen to a lot of classical music and opera, and seem to have been favorably impressed with Martin Logans, then you should give serious consideration to the Magnepan line, which you mentioned in your initial post. www.magnepann.com They are imminently musical, with superb soundstage and imaging. Their cohesiveness from top to bottom of the frequency range is exquisite. While they certainly work well with massive amounts of power, it is amazing how well they respond to more modest levels of clean power (giving the opportunity to enjoy them with less expensive electronics to get started but knowing there is even more pleasure to be had when you move up the power amp "food chain".)
                              A few years ago, I started my last upgrade quest with the plan to move up to Martin Logans from Def Tech BP-2000s, which had delighted me for several years -- until I heard a sensational HT demo of the Martin Logan reQuests in a 5.1 setup. (The movie was "Super Speedway".) But along the way, I happened upon the Magnepan 1.6s and then the MG 3.6s. They have a presence and sense of "you are there" listening to music that changed my upgrade plans. For HT, the detail and naturalness with which they render music and sound effects really draw you into the film experience. (Of course, the deepest bass and LFE should be handled by a separate sub.)
                              The Maggies are at least worth a serious listen.
                              Enjoy!
                              Burke
                                • 16196
                                I'll second Burke's recommendation. Magneplanars are one of the few commerically made speakers I've owned over the last 35 years. In fact, now that I think about it, they're the ONLY commerically made speaker I've bought in the last 35 years- everything else has been DIY. They are dipole, ya know, and they're very much worth a close listen. They are a bit of a chameleon; while they do like the power and current capabilities of large solid state amps, they're quite revealing of the mediocre midrange and treble of a lot of average solid state gear. Wouldn't pair them with Adcom, for instance. Aragon would be another matter though- fairly open midrange, and clean enough in the treble. Ayre would be even better....
                                ~Jon
                                • NMyTree
                                  • 520
                                  Jon, have you ever heard any of the Amps from Odyssey Audio, such as the Stratos Extreme.....or any of their Amps?
                                  Just wondering what your opinion is on their Amps.
                                  Tony
                                  • spiffnme
                                    • Apr 2003
                                    • 280
                                    If you want clean, responsive sound check out these...
                                    Energy Veritas series
                                    B&W 700 series
                                    Thiel
                                    Axiom Audio M60ti or M80ti
                                    Good luck and have fun listening!
                                    • MrWizerd
                                      • 5
                                      Thanks for all the replies guys, yeah i did mean deaf, I was watching the Def Comedy Jam at a very breif interval of time when I was typing. Darn you ebonics!
                                      Anyways, One of my major issues is that in order for me to make a high end sound dealer/ht dealer I would have to drive 4 hours wich is a major strain on my back, having had surgury to correct a major fracture of one of my vertebrea. So unfortunatly I am running on the recomendation of those wiser than I.
                                      But i am down to
                                      Mirage
                                      Definitive Technology
                                      Phase Technology
                                      Monitor
                                      and the Magnepan mabee if i can still do a 9.1 set up by purchacing 7.1 amp Unfortunatly i am Very short on space and while the magnepans for front and center would work unfortunatly they would not for the sides backs and front presence.
                                      • Burke Strickland
                                        • Sep 2001
                                        • 3159
                                        Have you seen the information on Magnepan's wall mounted MGMC1 speakers? http://www.magnepan.com/1-800-474-1646/mgmc1.html They are ideal in situations where space is short.
                                        Also, with the dipolar radiation pattern of the front mains (whichever model you might choose, floor standing or wall mounted) and their very lifelike imaging, you may find that the front presence speakers are not needed. However, if you were using a pair of MG 1.6s or MG 3.6s as your mains, a set of the wall mounted speakers could serve in that role (presence speakers).
                                        Also, having had a setup with front presence speakers in the past, I know that the demands on them are very slight compared to the others in the system and you might be able to make do with a small pair of wall mounted box speakers for that function.
                                        For full disclosue, I should add that I am using Magnepans for the front mains and center, and Def Techs for the surrounds (side and rear). The combo works great, but if I were buying all new from scratch, I'd go all Maggie. I just happened to have a pair of the BP-2000s and BP-20s on hand from a previous setup when I bought my MG 3.6s and MGCC1. :>)
                                        Good luck and good listening!
                                        Burke
                                        • tboooe
                                          My Impressions: 804S, Vienna Acoustics Beethoven Baby Grand, Martin Logan Ascent
                                          by tboooe
                                          Hi, so I am in the market for some new floorstanders as an upgrade to my recently sold 805S. I have already budgeted money for either the 804S or 803S. While auditioning both I also listened to some other speakers, just to make sure I truly wanted to stay with B&W. Of course there are many other...
                                          10 September 2005, 14:04 Saturday
                                          Parasound and Martin Logans
                                          I was in Seattle this past week, and just happened to see that Martin Logan was doing their US premier of their new flagship model, the CLX, at a Magnolia Hi-Fi there in Seattle. So I went, and was TOTALLY blown away by the performance. For a while now, I've thought that my next (and last) speaker...
                                          13 July 2008, 15:51 Sunday
                                        • RandyL999
                                          Halo equipment with Martin Logans
                                          by RandyL999
                                          I've been using a Yamaha Rx-V3000 receiver as a processor with an MX-830 for the mains, and two old Amber Series 70 amps to drive the center and rear speakers. I'm using Martin Logan Theater and Ascents for the front.
                                          Most of my use is for HT and DTS CD's at present, and upgrading to...
                                          24 January 2005, 15:24 Monday
                                        • =AirCeej=
                                          A View into the Rotel 15 Series Class D Amps
                                          by =AirCeej=
                                          During the process of putting another HT together, I began auditioning amps to replace a Sunfire Series 1 Load Invariant and an Anthem MCA20 – noteworthy at the respective price points in their day and for the Sunfire: novel. Appreciating the ideas and most of the execution designed into the Sunfire,...
                                          04 April 2009, 09:23 Saturday
                                        • Sunzui
                                          Martin Logans..Need a Receiver
                                          by Sunzui
                                          All,
                                          I am looking for some recommendations for a HT receiver to accompany my Martin Logans. I do have a $1,000 budget and the normal HT theater requirements.
                                          My B&K AVR202 just died recently :cry:
                                          Thanks ahead of time for the suggestions.
                                          21 October 2004, 09:40 Thursday
