Clean Power Level 3 vs 5 What is a good joule rating?
  • Britchie
    • Nov 2003
    • 45
    I have a MONSTER POWER HTS 3600 which filters power at level 3 with a 2960 joule. My dealer recently suggested I upgrade to a Level 5 filter. The device he has is 3145 Joule. Anyone care to comment on how noticable this would be? Would the sound improve dramatically?
    What is a Joule, what does it measure, and how high should a power filter be rated to be considered really good?
    Brad
  • Drew_W
    • Dec 2003
    • 75
    So he has you going for the 7000 series now? You're talking about $1200 for the HTS7000 versus $500 for what you already have...that's quite a jump...I don't think the HTS will improve your system *THAT* much more. The same $700 buys you a Musical Fidelity A3.24 DAC (Stereophile Class A) or a Rotel RB-1080 used...I mean, there's lots of other stuff you can put that money towards...and I say this without knowing what the components are.
    The thing with these Monster Power bars is that as you go up, you get MORE filters, and there comes a time when (not unlike the situation you're in now), if you really need to do more with your power, you should probably have an electrician come in and wire you some dedicated circuits for your audio components right from your electrical panel.
    I have a 3600 as well. If I ever upgrade, it'll be only to the 5100 Signature Series so that I can have blue lights instead of red, to match the rest of my rack (what a stupid reason, I know).
    And by the way, dealer discount for Monster product is 60%. Markup is around the same, pehaps just a little less. With that in mind, are you surprised he's pushing you to get a $1200 power bar? :twisted:
    • Drew_W
      • Dec 2003
      • 75
      Oh joules are a measure of surge surpression, by the way, and have nothing to do with power filtration.
      • Adz
        • Jan 2004
        • 549
        It also matters what kind of amps you have or may upgrade to one day. I purchased the HTPS7000 and then upgraded my amps to Bryston and CineNova. Both Bryston and CineNova very strongly recommend that their amps be connected directly to the outlet and not run through a power conditioner (regardless of the conditioner cost). So, I wasted my money there. I agree with Drew in that the money is much more better spent on dedicated 15 or 20 amp circuits. I am BIG proponent of doing this and to my ears its definitely made the most noticeable difference compared to other upgrades to my components (such as power cords, interconnects, speaker cable, etc.). By the way, I did get a 20% discount on the 7000.
        Adz
        • brendon
          • 245
          Is requirement for powerconditioning a North American thing?
          Hi I am intrigued by the use of power conditioners as I mostly see them mentioned by people in North America and I have seen little if any mention in Australian magazines or retailers, even ones that sell all sorts of hi end audio gimmicks.Is it because Australia mains voltage is 240volt 50hz rather 115v _hz or are we just slow to catch on?
          Brendon
          • bulitnv
            Advice on a Monster HTS 5100 MKii, stopped working
            by bulitnv
            Have several Rotel components plugged into the Monster HTS 5100 MKii.
            This morning when I woke up, everything had lost power. I checked all of the compoonents, they will all power up if I go to the wall, but the power conditioner will not power up. It was not emitting a buzzing alarm as the manual...
            27 September 2009, 09:57 Sunday
          • danyu
            Switched power outlet on RDC-7?
            by danyu
            Hi, I'm new to this forum. I'm planning to purchase an RDC-7, and was wondering if it has a switched power outlet to connect the remote AC control cord from my Monster HTS-5000. This way I could have my whole system turn on using the RDC-7 remote, rather than having to manually switch on the Monster...
            28 November 2001, 14:27 Wednesday
          • comeup
            Your System Please
            by comeup
            I've come to know a lot of names and personalities on this site and i'm curious to know what kind of systems you guys have. Two channel, home theater setups or both. Mines consist of:
            Home Theater System
            DVD: Denon 3910
            TV: Hitatchi 50' RPTV
            20 May 2006, 17:00 Saturday
          • vsarathy
            Power Conditioner Suggestions for 1095
            by vsarathy
            Could you guys offer me suggestions for power conditioners/surge protectors for my HT. Specifically, I intend to get a 1098/1095 and would like to connect them both to that unit. And, connecting the 1095 would, of course, require a conditioner with high-current ratings. BTW, what is the maximum current...
            28 October 2003, 13:17 Tuesday
          • boe
            Hum cause by plugging cable line into Monster HTS 5000
            by boe
            I was worried about potential damage caused by spikes in the cable TV line so I plugged into the in(made sure it isn't the out) on my HTS 5000. The hum on my subwoofer significantly increases when I do this.
            Any suggestions?
            29 January 2005, 12:26 Saturday
