2-channel amplifier or two mono block ?
  • audiofan
    • 272
    What the difference between mono block and two channel amplifier? I have an a/v. so the question is whether i should get a 2-channel amp. or 2 mono blocks? are they working the same ? Has anyone tried out Outlaw mono block?
    thanks.
  • Kevin P
    • 10812
    Well, two monoblocks would each have their own power supply, so there would be more reserve and less crosstalk between them, resulting in better imaging. But some 2-channel amps have separate power supplies for each channel so they're basically two monoblocks in one package.
    I've never heard the Outlaw monoblocks but I expect they're pretty nice given the quality of their multi-channel amps.
      Kevin, you beat me to it. :
      • aarsoe
        • 795
        I am sure some will disagree, but for me one added benefit would be shorter speaker cables and the fact that you can place each amp next to your speakers.
        Makes placement easier..
        • Kevin P
          • 10812
          Shorter speaker cables, but longer interconnects. I don't see much benefit there.
          • Bob
            • Jul 2000
            • 800
            "Shorter speaker cables, but longer interconnects. I don't see much benefit there."
            The arguement is that interconnects carry miniscule current compared to speaker cables therefore if one or the other needs to be long, better the interconnect. It is one of the differences that has a logical arguement but, is dubious in practice. It is one of those differences that you pretty much have to convince yourself that you can hear a difference.
            As to mono block v.s. stereo amp. Depends on the amps in question.
            • Kevin P
              • 10812
              Well, my argument is that a long interconnect is more likely to pick up noise or interference than a long speaker wire, and miniscule voltages are more affected by the capacitance etc. of a long cable than the higher power levels that speaker wires carry. Or maybe it isn't, I don't know! :??
              Also, speaker wire tends to be cheaper per foot than interconnects. Depending of course what interconnects and speaker wire you choose to use.
                • 16478
                Exactly Kevin I couldn't imaging what Doug would charge me for a pair of 20 foot long SilverCats :E
                  • 16205
                  Ah, yes... a highly varible factor. While I've tried to be a real bottom feeder as regards these items, i.e., good stuff that works but not at ridiculous prices, I find my self inching (well, maybe more like "yarding") upwards.
                  I understand the logic of the above arguements (speaker wires more immune to noise, but possibly tonally variable due to resistnace and inductance; interconnects SHOULD be less problematic with regards inductance and actual load current, but can be sensitive to noise).
                  However, achieving the best speaker cable performance DOES seem to require attention to the wire form factor and reducing inductance, and interconnects DO all seem to have some subtle tonal affects, apart from any issues with noise pickup; they certainly do differ as regards tonal balance and transparency, more so than background noise in my system. Still, they don't have the kind of impact that variation in quality of digital sources has, or power amps, for example.
                  These are all comments that are valid on a "modest" sytem with a good 8" two way... doesn't have to be something over the top like ThomasW's Acoustats+RD ribbon rig.
                  • aarsoe
                    • 795
                    I think you guys are forgetting one thing..
                    Interconnects are generally shielded - and speaker wire are generally not. Especially true if we are talking about high end stuff....
                    ANNNNDDDDDDD, then I will slam my ace on the table - Balanced interconnects! ;s@
                    Roll over and die!
                      • 16478
                      True but the type of signal they carry is completely different so you don't typically need shielding in speaker cables
                        • 16205
                        Roll over and die!
                        I'm assuming your point is that it's OK to run longer interconnects, especially balanced....
                        Did I ever tell you the story about my 3 meter Ayre signature balanced interconnects? They're great, the best I've ever heard; but they're about the same price as a pair of Cardas Neutral reference the same length... which is to say, not cheap. I think the Ayre are better, musically. Now, imagine doing six channels of those...
                        In comparison, my home brew 8TC speaker cables are pretty cheap, as detailed in an old thread on the MissionPossible DIY forum. Point is, it would be much less expensive to have long runs of 8TC (which is equivalent to 9AWG) than long balanced interconnects that I'm using. This setup allows me to have a stereo amp positioned in the middle between the speakers, and have the preamp/source component rack off to the side.
                        So, still not sure about the correct call. But then, it's my fault, too, because I needed a long stereo cable for my preamp to stereo Ayre amp. If was running the Palladium monoblocks, instead of having them hold down the carpet in my daughter's bedroom, I could have possibly optimized lengths a little better, but not much- I don't put source gear right on top of the speaker system. It's too close as it it.
                        ~Jon
                        • Kevin P
                          • 10812
                          What the Prattmaster said... if a speaker cable picks up noise, it will be too weak to affect the much stronger signal driving the speaker. When an interconnect picks up noise, it gets amplified and then sent to the speakers at a much higher level.
                          This is why speaker cables don't need to be shielded, but interconnects do. The weak signals interconnects carry would tend to be affected more by long runs than strong speaker-levels signals.
                          I think we veered way off the original topic, which was monoblocks vs. 2-channel amp. There, it depends on the amp. If the manufacturer offers both options, try both and see which works better in your setup. Some 2-channel amps have separate power supplies for each channel (an Adcom I repaired once was like this), so they're little more than two monoblocks in one package.
                          • aarsoe
                            • 795
                            Agree - this was a picnic of the issue - but I could not help it. :lol:
                            • mark4x4
                              Bi-amping versus mono block amps
                              by mark4x4
                              I'm currenting running a Aragon 8008 MKII for my front mains and an Aragon 8008x3 for my center and surrounds. I want to improve the sound in two channel mode. Which configuration would give me the best sound quality bi-amping or going to mono block amps like the Aragon Palladium 1K. If it matters...
                              27 February 2005, 19:17 Sunday
                              Benchmarking the Benchmark... AHB2 Amplifier
                              OnTheBench.key by Jon Hancock, on Flickr
                              You know, sometimes you know right away good things are happening. In this case, there is no mystery... I've seen the other reviews... I've seen John Atkinson's measurements on Stereophile...
                              The Benchmark AHB2 is a nicely proportioned...
                              16 April 2016, 22:07 Saturday
                              The Benchmark AHB2 is a nicely proportioned little amp that seeing just a picture of the front...
                              07 March 2016, 20:30 Monday
                            • Supernova
                              Modulus-686 - Stereo Amplifier Build.
                              by Supernova
                              Hello all!
                              I wasn't sure where to put this within the forum but since it is somewhat of a DIY project I thought I'd post it in the Mission Possible DIY area, if this is the incorrect area mods please move it to the correct area.
                              I never intended to build my own amplifier...
                              07 February 2019, 16:40 Thursday
                              Mono block build thread- using GhentAudio chassis
                              The new Ghent Audio chassis I just ordered arrived yesterday, so it's time to start a thread about construction of mono blocks using them and the SMPS1200A700 power supplies. Won't be a lot of action for a while, as I'll have a lot of electrical work to do, but I will get them put together with the...
                              12 January 2016, 09:31 Tuesday
