Well... tunneling my cables to the rear speakers was quite a mission... 45' of stranded copper.. but as going through the walls i only needed 33' for the rear left speaker & 45' for the rear right speaker - i bet you thought about it yourself once or twice.. well the question is - should i cut both cables to 45' (with 12' of leftovers) so i won't have any difference in the signal strength, or need i cut it 33' & 45' and could never tell the difference.. scientificly i guess it's the 1st. choice... any audiophile advice ?
Speaker cable length - does size really matters ?? ;)
Audiophily and with leaving nothing to chance, cut them both the 45'. However do *NOT* bunch up the extra 12' or wind it up in a circle. Ideally, lay the cable roomy enough that you do not get windings, but still get correctly to the end.Originally posted by GadgetsWell... tunneling my cables to the rear speakers was quite a mission... 45' of stranded copper.. but as going through the walls i only needed 33' for the rear left speaker & 45' for the rear right speaker - i bet you thought about it yourself once or twice.. well the question is - should i cut both cables to 45' (with 12' of leftovers) so i won't have any difference in the signal strength, or need i cut it 33' & 45' and could never tell the difference.. scientificly i guess it's the 1st. choice... any audiophile advice ?
Quite long distances btw, can't you put your equipment closer?- Bottom
Absolutely, same length is best for timing issues. Now in all truth, it likely would not be audible by your ears. But that doesn't mean the difference doesn't exist, and it's on that basis that most true audiophiles would seek the grail, and make them the same length.
Lex
Cable Guy DVD Collection
"I'm out there Jerry, and I'm loving every minute of it!" - Kramer- Bottom
if you're speaking from an engineering perspective yes the cables should be the same lenght....BUT in the real world for you to be able to hear any difference between two cables of unequal lenght they would have to be extremely different lenghts (as in 1 inch vs 1 mile) and you couldn't move an inch from the perfect sweet spot. Short answer is don't worry about it just use what you need. Its actually far worse to have excess cable that's coiled up to maintain the same lengths as it would be to just trim off the extra and use what fits.
The signal moves through the wire at the speed of light (~300,000 kilometers per second or 186,000 miles per second) 8O
As a result a few feet of wire one way or another isn't going to cause timing issues. It's possible that the increased L/C/R of the wire is enough to cause minor voicing changes.
If you have enough spare wire cut a 30' & 45' length and give them a listen before putting them in the walls. That will answer your question.
As Scarp noted don't 'coil' any excess wire, it should instead be 'fan-folded' to avoid creating an inductor....
Speaker cable length affecting phase differences, timing issues? Forget about it.
Yes, electricity does travel near the speed of light in a wire (depending on its specific velocity factor), but that's not important here. This speed is approximated to about a nanosecond a foot.
An acceptable example would be that if you had one speaker wire 50 feet longer than the other, then that signal would arrive about 50 nanoseconds later than the other. Well, this is about 1000 times less than human hearing can even begin to detect, so don't worry about the lengths of your cables and phase differences.
If you hear the difference, you won't need a receiver to listen to local radio stations, your ears will do the job for you...... :LOL:- Bottom
While that is likely very true, it does not change the fact that there is "a" timing difference, even if miniscule in size. I still like to keep things equal, as do a lot of other people. Why have any difference at all if you don't have to? That's my thinking on it. I don't sell someone a 5 meter RCA cable, and a 1 meter. I sell them like sizes normally. Speaker cables should be no different. That's why they are called a pair, if they aren't the same, they really aren't a pair.
Lex
because more often then not there's a difference in the distances between the and and right speaker and its better to cut the cable to match the required lenght then to coil up excess.Why have any difference at all if you don't have to?
As for their being a difference sure there "is" but its going to be masked by so many other variables why bother worrying about it.
I'm not opposed to people keeping them the same lenght just so long as they're not comprimising something else as a result.
Exactly. And here we've only focused on phase issues - which I think we've established as a non-issue.because more often then not there's a difference in the distances between the and and right speaker and its better to cut the cable to match the required lenght then to coil up excess.
With respect to the far more significant increased low pass filter effects exacerbated by longer cable lengths, why would Gadgets leave an extra 12 feet of low pass filter crammed behind his couch when he can cut it to length as Andrew suggests and realize a benefit for that speaker at least?
brucek- Bottom
We'll agree to disagree here. As far as this being "masked", masked by what? I'm sorry but that makes no sense. If we are talking 2 channel, there's one thing going on with music and it's the music coming out of 2 channels. Other than accoustics, there's no other variables. Those 2 speakers are either timed as close as the electronics will allow, or they are not, it's your choice. I've made mine and decided what I recommend. It's a small difference, granted, probably couldn't be heard by the best golden ear. But that still doesn't mean he wants to leave it to chance.
Lex
Slight differences in the crossover components (actual values), one cable running // to a power cord, your head moving 1" to the left of perfect centre etc. any one of those would have a great effect on what you hear then a difference in a couple of feet of cableAs far as this being "masked", masked by what?
Is a variation in resistance a possible issue? Not being a poobah on things EE, I'm curious. . . . :huh:
David - HTGuide flunky
Our "Theater"
Our DVDs on DVD Tracker
Those 2 speakers are either timed as close as the electronics will allow, or they are not, it's your choice.Mmmm, so our question is whether 12 feet extra of speaker cable has a greater effect on (timing of the electrical signal) or the (frequency response) of the signal. We certainly always want the best sound possible, so it's worth looking at.Is a variation in resistance a possible issue? Not being a poobah on things EE, I'm curious
Well, an extra 12 feet of cable would cause the signal to end up at one speaker about 12 nanoseconds late. This calculates to a hearing requirement needed to perceive this signal delay of about 83 MHz - read megahertz (which is just below the FM radio broadcast spectrum) . Humans can hear up to 20Khz (that's kilohertz). I think we can put that issue to bed.
Regarding wire length, if we're using 12 gauge wire, what length would significantly disrupt frequency response and system damping.
Well, that's a tough one to answer as each listener is different. The question is always , "How much performance am I willing to lose"? - because, no matter what, you'll always lose performance with any speaker wire. The longer it is - the worse it gets.
The best caveat is of course to keep your speaker wires as short as possible. Monoblocks are desirable because you can place them close to the rear of the speakers and use super short speaker wires.
There are lots of rules of thumbs for acceptable percentage loss in signal across a speaker wire. Most people would find the values unacceptably high. The rule says you shouldn't lose more than 10% of your power in your speaker cable and that a system damping factor of greater than 10 is OK. I don't find those figures acceptable, but there you are...
It's easy to calculate your losses at certain frequencies for a given wire and amplifier and speaker impedance, but its boring and better to stick to making sure you keep speaker wires as short as possible.
Anyway, I'll give you an example of our 12 gauge at 12 feet.
Typical 12 gauge cable exhibits a DC resistance of about 1.619ohms per 1000ft. This DC resistance is not frequency dependant and can be calculated as to the loss you'll experience for every foot in relation to an 8 ohm speaker for example. Basic math.
Next value to consider is inductance per foot of the wire. A pretty good estimation of inductance per foot for most gauges of speaker wire is about 0.20 microhenrys/foot. Yes, the higher the gauge (smaller wire), the higher the inductance, but it's really, really insignificant.
Inductance (and capacitance) are both properties of wire that create frequency dependant resistance (this is AC resistance).
For inductance, as the frequency goes up, the resistance increases. This resistance is actually called inductive reactance - no matter. What matters is that it is a resistance that is in series with the speaker loop and it will create a loss.
The fact is, the higher the frequency, the higher the resistance caused by the inductance, and remember, the longer the cable, the more inductance increases.
For capacitance, since this a low impedance connection, we can essentially disregard it and the bypass reactance it causes. Capacitance is only a player in high impedance connections such as interconnects between preamps and power amps. It's too small an effect to be considered in a speaker connection.
Let's pick two frequencies of interest - 100Hz and 20KHz.
The DC resistance is the same at both frequencies and calculates to 0.039ohms for 12 feet
The inductive reactance (XL impedance) at 100HZ and at 20KHZ is:
@100Hz = 0.0015 ohms
@20KHz = 0.30 ohms
So a 12 foot piece of speaker cable has an approximate impedance at the two frequencies of:
@100Hz = 0.039 + 0.0015 = 0.04 ohms
@20KHz = 0.039 + 0.30 = 0.339 ohms
So how is that significant in relation to an 8 ohm speaker:
@100Hz = power loss in speaker cable of 0.5%
@20KHz = power loss in speaker cable of 4.1%
Assuming a typical solid state amplifier output impedance of .05 ohms yielding a damping factor of 160, then at the 100Hz impedance of the wire where damping factor is significant, it will be lowered to about 88.
What's this mean? Well, it means 12 feet of 12 gauge is pretty darned good, but at 20KHz you can see that the inductive reactance is starting to overwhelm the formula and a loss is creeping in, evidenced by the 4% power loss figure and resulting in a softening of the upper audio frequency range (essentially this is a low pass filter - did I hear someone say wire doesn't matter). Well, no way you'll likely hear that loss, but the conclusion I come to on this question is:
If you have an extra 12 feet of speaker cable not used, it will affect the frequency response and will not affect the timing. Cut the wire to length.
brucek- Bottom
Excellent post, Bruce! Thanks for the information. :T
Our "Theater"
i thought that since speaker wire was far less likely to pick up interference so you should always opt for longer speaker cables then interconnects?The best caveat is of course to keep your speaker wires as short as possible. Monoblocks are desirable because you can place them close to the rear of the speakers and use super short speaker wires.
It's really a question of which situation has the greater negative effect.
The speaker to power amp connection, operates in the current domain. This is an extremely low impedance interface. The output impedance of most amplifiers is less than 0.1 ohms feeding a speaker and crossover system with impedance's that vary from 4 to 8 ohms. You have to appreciate the upsetting factor that simple cable resistance and inductive reactance can add to this scenario even in relatively short lengths.
Because the speaker is in the order of 4 - 8 ohms, a long speaker run, particularly one of high gauge (small wire) can become an appreciable proportion of the speaker impedance and as such can affect a signal loss and change of system response combined with decreased system damping. The system damping formula is almost exclusively driven by the speaker cables impedance, which is a function of its resistance and inductive reactance (capacitive reactance can be ignored here).
The interconnect between a pre amp and power amp is a line level, high impedance connection which is essentially a voltage bridge and is indeed (as you stated) susceptible to noise in long lengths, but this is taken care of very nicely in a home environment by using standard coaxial cable with a good (100%) shield - so there's no real problem there.
There is (almost) no power transfer in an interconnect interface. The preamp acts as a voltage source and as such almost no current here, only voltage. So you could use 20 gauge or 10 gauge and it would have zero affect on the voltage feeding the power amp. In that regard the DC resistance of a long length isn't a factor to be considered as it is with a speaker cable. The only concern with the interconnect is cable capacitance which increases with length. The resulting capacitive reactance shunt has an appreciable effect on high output impedance devices such as passive pre amps and tube preamps. In those cases a short interconnect is preferred. But in solid state pre amps with their very low output impedance the minimal low pass effect of a long interconnect wins out over the long speaker cable.
It's really the main advantage (besides channel separation) in owning monoblocks. Place the monoblock as close as possible to the speaker and run long interconnects. Choosing interconnects with as low a capacitance would be advisable.
The problem of course is that reality steps in and because of equipment location concerns etc., you often have to compromise on this long/short deal. Myself, because my two channel is so important to me, I have my power amps close to my mains and my preamp close to the power amp. It allows me to use both short interconnects and short speaker cables of 9 gauge. For my rears (where I don't really care, nor consider 5.1 critical listening) I have long speaker cables.....I don't really care if I lose a few percent in the speaker runs to the rear.
brucek- Bottom
by JohnnzToday I followed the calculations in the 3" Precision Port instruction sheet and calculated two different values. One based on the original Nat P thread that recommends a tuning frequency of 28Hz for a 50l box, and one based on Opt E's "Yet another Nat P" thread which goes for 32Hz tuning....-
Channel: Mission Possible DIY
by frascatiI posted this before, but I think the details might have dissuaded anyone from attempting it. Here's a much easier version that works just as well. Turns out that one flute works as well as two since the guide keeps it so stable. That really simplifies the build.
I was getting something...-
by Shane MartinHaving seen Pitch Black just this year I was intrigued by the sequel(I'm hearing that 2 more are wanting to be made now..) also having missed this at the theater and liking this type of movie I knew I'd buy it. My expectations were rather low going in due to a piss poor showing at the box office plus...-
Channel: DVD Director
by G12345567My setup is as follows.
Amplifier: Marantz SR5200
Centre: LCR60
Front L & R: 602s3
Rears L & R: 601s3
and a 3rd party sub (rca connected)
at the moment the fronts and centre are bi-wired using the following grade cable.
Channel: Club B & W Speakers
by bikedaveAlright, well, I have finished my sub all except for the finish. So now I have time to post some pics and description. I would appreciate any feedback as I will no doubt get a case of what someone else has aptly called "upgraditis." I would like to thank ThomasW, ---k---, and Kevin Haskins...-
- Loading...
- No more items.
