Alright, well, I have finished my sub all except for the finish. So now I have time to post some pics and description. I would appreciate any feedback as I will no doubt get a case of what someone else has aptly called "upgraditis." I would like to thank ThomasW, ---k---, and Kevin Haskins for their tidbits of truth. I will be posting pictures and thoughts over the course of the next few days hopefully.
The first picture below is the tube all ready to go, if it looks like it has a seam its because it does. I had two 20" Diameter pieces roughly 40" long, but i needed one longer one to achieve the 300liter I wanted. So I cut one to length i needed to add on and stuck it on top. Then, as you can see in picture #2, I cut maybe an 8" long piece of tube, then cut out a section of it so I could squeeze it down inside the big tubes. I slid it into place at the seam, glued it and then drove a wedge in the gap which I had sawn in order to get it in. Then I screwed it from the outside, so it is secure.
Then, in picture #3, you can see my sophisticated circle jig. I wanted to keep cost down obviously so I just took my time taking measurements and cut really carefully with my jigsaw.
