BI-wire question
  • ht_addict
    • Dec 2002
    • 509
    BI-wire question
    I'm going to Bi-wire my new Paradigm Studio 40's and CC470v3 and was wondering should the runs of speaker wire be the same length for the front soundstage(FL: 1ft, FR:7ft, Center: 4ft from amp, so should I make all runs say 8ft). I know the runs should be the same length going from the amps +/- to both +/- terminals on the speakers.
    ht_addict
    • 16478
    Actually I wouldn't worry about the cables being the same lenght at all...technically they should be but in the real world you'd have to keep your head at the exact same spot for the differeing cable lenghts to be an issue...even then you'd need bat like hearing That said if possible it might make you feel better that they're the same lengh and as we know the mind can me far more influential on what you preceive then what the bench test tell us that it might be worth the investment in time and effort to at least in your mind make them the same.
    • dixon
      conecting biwire speakers to Rotel 1075,advice please
      by dixon
      I want to conect my biwire surround speakers to Rotel 1075.I have conected right now only the center and surround speakers to Rotel 1075 and the front it's conected to the main amp.Can I use the extra channel from Rotel to biwire my surround speakers?How can I do that?I will have a better sound for...
      01 December 2004, 17:56 Wednesday
    • Rolex
      Biwire suggestions for 805S
      by Rolex
      I'm currently using the new 805S with a mucical fidelity a3 integrated and rotel rcd-1072 cd player. I'm also using transparent audio music wave plus speaker cables. I would like to go to a biwire configuration since that is what B&W suggests. Has anyone used Signal cable Classic biwire? I'm...
      22 March 2005, 11:45 Tuesday
    • See-Fu
      BIamp w/ receiver or biwire
      by See-Fu
      I have a rotel 1057 receiver and a krell amp. Should I just biwire w/ the krell or should I bi amp with the receiver and the krell amp?
      08 December 2006, 19:08 Friday
    • See-Fu
      Biwire center channel
      by See-Fu
      Does it make much sense to biwire a center channel?
      12 December 2006, 10:53 Tuesday
    • tony_M
      Helps Pls... Biwire cat 6
      by tony_M
      Hi All,
      Pls help me some idea construction on biwire cat6
      I mean like how may pair going to High and low
      tks
      02 February 2011, 12:57 Wednesday
