Helps Pls... Biwire cat 6
  • tony_M
    • Nov 2010
    • 28
    Hi All,
    Pls help me some idea construction on biwire cat6
    I mean like how may pair going to High and low
    tks
    Each doubling of wire area makes an equivalent of a wire three gauges larger. http://en.wikipedia.org/wiki/American_wire_gauge
    For example, one pair of 24 gauge wires are equivalent to a 21 gauge wire. You'll need 16 strands of 24 gauge wire to approximate a 12 gauge conductor if that is your target.
    Check out forum sponsor cat cables.
    • Warrant
      • Dec 2010
      • 54
      Are we allowed to post links to other DIY sites?
      • numberoneoppa
        • 535
        Yes, go ahead.
        -Josh
        • Warrant
          • Dec 2010
          • 54
          http://www.avsforum.com/avs-vb/showthread.php?t=740215 a great how to and advice. This plus gauge calculations should have you well on your way.
          • fjhuerta
            • 1140
            It's a nightmare. I once did one with.. I dunno... it was the equivalent of 12GA wire or so. It took me two months. It sounds the same as zipcord. YMMV.
            Javier Huerta
              +1...
              • 1Michael
                • 293
                I run 1 cat5 cable for the positive and 1 for the negative. KISS I always say. doing all that other stuff is just too much bother LoL.
                Michael
                Chesapeake Va.
