Equipment "breakin" all in our heads?
  • hal
    • Jul 2003
    • 25
    When I hear people discussing the impact of "breakin" on their listening experience I often wonder whether this is not simply dependent upon the time it takes our ears to adjust to a new reality. If you've ever had your ears cleaned out of wax buildup you will notice a very dramatic change in your perception of your own voice and that of other people -- "S"'s sound overly crisp, every rattle of the newspaper is annoying. This lasts for 24-36 hours and then disappears! It's not that our ears get plugged up again, instead we adjust our perception of what we hear and re-equalize everything to a new normal sound. I wouldn't be surprised if a similar thing happens with new equipment. As our brains adapt to the new reality the sound "improves". I'll bet even old equipment goes through a break-in phase when given to a new listener! Comments?
  • Burke Strickland
    • Sep 2001
    • 3159
    While a lot of the differences people swear they hear in various equipment probably are psychoacoustic or placebo effects, some equipment actually does "break in". But the extent of that effect varies by type of equipment and make and model (due to design differences and manufacturing techniques). Solid state gear such as power amps may "break in" for about 15 seconds while capacitors initially form their charge, etcetera, and from then on, unless the equipment is defective, there should be no real change in their performance. Other kinds of equipment may take longer. For instance, with some speakers, the drivers "loosen up" with extended play and the frequency range extends. This is measurable with instruments that are not subject to changeable “human perception".
    Since I was a bit skeptical about "break in", but had been advised to do it with my speakers, I measured my Magnepans with an SPL meter and test tones immediately upon setup but before the "break in" procedure began and then repeated the tests after the recommended “break in” time. The SPL meter measured response that went about 10 hz lower in the bass at useable volume (IOW was registering at the same "reference" level all the way down to that frequency).
    Burke
    Spelling and grammar checked in MS Word. If you detect an error, please contact Bill Gates.
    • Danbry39
      • Sep 2002
      • 1584
      Good topic Hal.
      Having spent the last few days breaking in speakers with a minimum 60 hour recommended break in period, I, like Burke, strongly believe that break in does change the sound. With speakers, drivers, especially the bass, need to stretch a bit to perform optimally.
      During my particular instance, I compared certain sounds on specific recordings right off the bat and returned to these same recordings many hours later to hear if the sound had changed, to catch things like soundstage, piano, vocals, brass, drums, etc, and, while there might have been some psychoaccoustics going on, most definitely changes did occur and, given what I want out of a speaker, the changes were very significant to me personally.
      A lot of people would validly point out that the time lapse between the initial and subsequent testing on my part is very inaccurate, which is probably true. I also wouldn't deny the possibility that, over time, one becomes acclimated to a speaker's sonic footprint. Still, some of the changes were pretty noticable.
      I will say that this would vary from speaker to speaker depending on things such as the types of drivers being used.
      Keith
      Keith
        • 27460
        While some psychoacoustic adjustments can occur when listening to new gear, or we become unsentisized to the sounds were used to, that doesn't change the fact that break in with various components can be very real.
        1. speakers
        2. tubes on tube amps
        3. Internal wiring
        4. cables
        5. Possibly transistors, capacitors, resistors, etc...
        Like Danbry said, amplifiers technically break in every time you play them unless the amplifier is kept "warm" in a suspended state of standby. Even then, when full power is applied, the break in process takes some time before the amp sounds it's best, EVERY time you turn it on.
        Lex
        • Burke Strickland
          • Sep 2001
          • 3159
          Some people distinguish between the "warm up" period necessary to get to optimal operating state each time you turn on a piece of gear and a one-time initial "break in" which fundamentally changes its physical characteristics (as opposed to the operating condition) of the gear. And others still claim it's all in our heads. (But that's just an opinion, not "god" talking.) :>)
          Burke
            • 27460
            I realize that myself Burke. My point was to illustrate that sound can change in a component, that technically is warming up, but it reflects a change in state due to an amount of time required to reach optimal performance. Similar concept, even though different than a 1 time change occuring due to break in.
            Lex
            • Jeff Hartford
              • Jul 2003
              • 53
              Read a very erudite review of the Denon 2900 where the reviewer laughed at people evaluating the unit right out of the box. He noted a very obvious evolution of the product sonically over a three week period. Fantasy perhaps, but he sounded so convincing with that British accent.....
              Jeff
              • LarryB
                • Dec 2001
                • 81
                There's an article in the most recent edition of Hi Fi + in which the author was unable to measure any changes in a speaker (B&W 805, if memory serves) before and after break-in.
                Larry
                • craigdcan
                  • Dec 2002
                  • 42
                  I suppose there is no real answer, but Paul Barton(PSB) has done several measurements and has come up empty, claiming that there is no difference after "break-in". Respect his opinion, or not, I think a good deal of it is in our heads. Just like anything else....once you've had something for a few years, you like it more than the first day. Once you own something you are guilty of POO(pride of ownership), even though you own this product because you chose it against the competition.
                  While I could never give a definitive answer, I would like to use this to say that "measurements aren't everything"....
                    Home Theater, A/V Equipment, and Gender
                    You know, I was thinking: The world of A/V enthusiasts and home theater freaks, of which I'm admittedly a member, is mostly populated by men. That seems to be just a fact. What I've wondered about is why. I came across an article on the Klipsch website touching on this issue from the female perspective:...
                    06 December 2003, 07:13 Saturday
                  • thyname
                    "Breaking in" equipment or ears??
                    by thyname
                    Hi guys;
                    When I first got my RCD-1072 I felt it sounded very harsh at the beginning and much better and warm in a week or so after several hours of play. That was all my certain perception. However, at another forum I participate, several guys argue against the concept of "Break...
                    13 April 2005, 15:34 Wednesday
                    Fed-up with break-in delays? Tired of having cloth ears?
                    by bigburner
                    Have you ever wondered why Boeing can put a brand new 777 into the air and it lands at the right airport without any break-in of the electronics and wiring?
                    Have you ever wondered why an AIM-120D air-to-air missile can hit its target in all weathers 130 miles away without any break-in...
                    07 October 2009, 03:53 Wednesday
                  • mb225
                    Rotel Electronics Break-in. Bona fide or Bogus?
                    by mb225
                    I recently bought a Rotel RB-1582 Amplifier and a Rotel RC-1550 preamplifier. I have heard a lot of people say that the amp/preamp will need to be "broken in". I wanted to start this tread to find out what other people think about this concept? Do you think that solid state audio electronics...
                    Break-in is BS! I think break-in is just your ears adapting to the sound
                    34.29%
                    12
                    Break-in is just something dealers use to keep you from returning your gear
                    2.86%
                    1
                    I don’t believe in break-in. I think electronics need to be warmed up which should take 15-60 mins
                    14.29%
                    5
                    Break-in is real; but can only account for very minor changes and happens in 50 hours
                    2.86%
                    1
                    Break-in is real; but can only account for very minor changes and happens in 200 hours of use
                    2.86%
                    1
                    Break-in is absolutely real. Electronics should reach full ability after 1-50 hours of use
                    5.71%
                    2
                    Break-in is absolutely real. Electronics should reach full ability after 50-200 hours of use
                    28.57%
                    10
                    Break-in is absolutely real. Electronics should reach full ability after 200-400 hours of use
                    5.71%
                    2
                    You need 400+ hours. Things will change for years, the more you use it the better it gets
                    2.86%
                    1
                    16 February 2010, 14:56 Tuesday
                  • bullitt731
                    804s Breakin
                    by bullitt731
                    I am upgrading to the 804s and HTM3s in my front end. To do this I have had to sell my 1080 amp which was paired with my 1056 receiver. I will be buying the new Rotel separates when they come out at some point. I know the 1056 is not enough power to really make these speakers sing but does it have enough...
                    05 September 2006, 14:29 Tuesday
