I'm contemplating a tube integration into my SS system. Here are the current components.
Paradigm Studio 100's
Anthem AVM-20
Sherbourn 7/2100
Sony 555ES
Cat Cables
The questions are many, but I'll begin with some basics.
The units I am considering are the following.
Jolida 1000A
http://www.jolida.com/catalogue/jd1000a.html
Jolida 202A
http://www.jolida.com/catalogue/jd202a.html
Rogue Sixty-Six Preamplifier (20 minutes from my residence)
http://www.rogueaudio.com/66.htm
My intentions are to use this primarily for 2 channel listening. Initially, I was just going to purchase the Jolida 202A, connect to the Anthem's pre-outs, connect the speaker cables to the Jolida and then when I listen to 2 channel, make the manual wire switch on the speakers to listen to the tubes. I understand this method of connection. It's a bit of a hassle, but something I can live with.
Then after talking with someone/sales person today, he said the Pre-amp would be the easiest integration. He suggested connecting the pre-outs to the AUX on the tube pre-amp, moving a switch to the one o'clock position on the tube pre-amp or something like that. Forgive my ignorance here.
Questions are:
1. Does anyone have experience with any of these components? Suggestions and comments are appreciated.
2. The connections to the Anthem using the tube Preamplifier is very confusing to me. Could someone explain this procedure to me? Connections 101.
3. Is this a worthy endeavor considering the type/level of equipment I own?
4. Any web sites or url's that you would recommend so I can educate myself before I take a walk on the wild side? My normal haunts seem to be limited with information after many searches.
Thanks are always in advance,
Charles
Anthem AVM-20
Sherbourn 7/2100
Sony 555ES
Cat Cables
Jolida 1000A
Jolida 202A
Questions are:
Charles
