vertical bi-amp, need info
  • Bob
    • Jul 2000
    • 800
    I would like to experiment with vertical bi-amping using my Casablanca, Dreadnaught and Vandersteen 3s. The question I have is, do I need splitters at the Casablanca? If so, do balanced splitters exist?
    • 16178
    By vertical bi-amping, I'm assuming what you mean is using two channels of amplification running full range for each speaker section, but running only the bass section on one amp, and the treble section on another. This lowers the current loading on the amplifier, but not the voltage swing requirments. With some amplifiers, people do report better results, somewhat less IM modulation because of the lessened current demands. You don't get the full benefit of bi-amping, with an electronics crossover, because you'r still handling the full voltage range on each amplifier. (If this is not what you are hoping to do, please explain further).
    A source of splitters for this task doesn't readily come to mind- it wouldn't be hard to make a patch box for this. My Ayre V-5, and many pro amps, have a pass thorugh balanced connection, with a mail and female XLR provided, wired in parallel; this is called a balanced bridging connection, because the amplifier isn't terminated in a 600 ohm line load, anyway. The Theta Dreadnaught does not offer a pass through connection on the XLRs.
    What is your speaker system that you're considering bi-amping/bi-wiring?
    • Bob
      • Jul 2000
      • 800
      First of all thank you for your reply. Let me say that I am not really sure what vertical bi-amping is. So, why do I want to try it? I'll explain. I am using Vanderteen 3A Signature speakers in my system. I used to have a Audio Research MKll, 100 watt per channel amp when I first purchased the speakers. This I blew up in a moment of exuburance after returning from a concert and cranking up the volume a wee bit to high. Because of the flames and such I sort of became leary of tubes and switched to a couple of Jeff Rowland amps which I also managed to overwhelm with some Pink Floyd one strange night. Thinking that more power was needed for these speakers I purchased a Dreadnaught. Then I read that Richard Hardesty was using the Dreadnaught for his 3As in a vertical bi-amp configuration. Since he didn't say that he was bridging the modules I figured that it means that one module feeds the bass and the other module feeds the mid range and tweeter. Is this correct? And if it is, don't I need a Y at each output of the preamp? And since I am using balanced interconnects I was wondering if anybody makes a balanced Y.
      Then again, maybe I totally read to much into the term vertical bi-amping and it is just another term for bridgeing a amp.
      Oh yeah, I forgot to say why I wanted to try this. Because I got a bunch of amps laying around and figured that since I had the power I might as well hook it up and see what happens.
        • 27460
        Bob, I potentially could build an XLR splitter. But not really sure I want to, to be honest. It would be a royal pain in the butt, working with XLRs on such a small cable. I am sure.
        I would consider it, but it wouldn't be cheap. I am not sure about your terminology of vertical bi-amping. Are your XLRs 3 pronge?
        Nice to see you back posting after a brief hiatus.
        Lex
        • Bob
          • Jul 2000
          • 800
          Lex,
          "I am not sure about your terminology of vertical
          bi-amping. Are your XLRs 3 pronge?"
          That's o'k, I'm not sure what it means either. But, I beleive it means the following:
          You take a speaker that can be bi-wired and feed each half of the speaker with a different amp. So, if you were using mono amps, each speaker would need two amps.
          I have found the balanced splitters, or Y's, at Audioquest. Now, I just need to find out if my interpretation of vertical bi-amping is correct and would I be losing anything by spltting the signals coming out of my preamp.
          • specialized
            Horizontal and vertical BiAmping??
            by specialized
            While i'm looking for amp solution for my HTM3S, i found out this types of biamping.. .Can somebody explain me what is vertical and what is horizontal bi amping?
            Greetings
            Darko
            17 September 2008, 06:03 Wednesday
          • jorgjean
            Biamping with RMB-1075?
            by jorgjean
            I'am planning to bi-amp my speakers KEF XQ5. They would receive power from an RMB-1075. Has anybody got experience with this vertical biamping. Will there be differences in the output level of low-and high frequencies as the resistance will be different?
            How about linking 2 Channels to...
            15 November 2005, 14:48 Tuesday
          • rickp
            balanced outputs hum
            by rickp
            I have tried using XLRs to connect my RDC 7 to a Dreadnaught but I get hum. It goes away with RCAs. It has been suggested that the RDC uses a different ground system than the amp. I dont know much about all that grounding business but, I would like to know if it is possible, to use XLRs with this combo...
            26 October 2003, 23:04 Sunday
            SATV/CATV, Splitters & Amps - Questions, Questions
            by David Meek
            O' mighty Poobahs, once again, I need some education. This time, it's on CATV, RG6 cables, splitters and cable signal amplification.
            Here's the deal: I'm running cable to a room in our house that doesn't have it. It's a downstairs room which means I can't easily tie into the CATV cables...
            10 August 2004, 12:45 Tuesday
          • Jon SS
            Using the RDC-7 with the Theta Dreadnaught - question?
            by Jon SS
            Since the Dreadnaught power amp has two 12v remote triggers one for surround and one for stereo, can the RDC-7 be set up to send the appropriate signal to the power amp to distinguish between listening to stereo and surround? Therefore only two amps would be switched on and used when listening to stereo....
            23 January 2003, 17:51 Thursday
