SATV/CATV, Splitters & Amps - Questions, Questions
    O' mighty Poobahs, once again, I need some education. This time, it's on CATV, RG6 cables, splitters and cable signal amplification.
    Here's the deal: I'm running cable to a room in our house that doesn't have it. It's a downstairs room which means I can't easily tie into the CATV cables in the attic. My best choice is to tie in where the underground run from the cable company comes out of the ground and splits into two runs for the up- and down-stairs outlets. From that initial splitter, it's about a 60' run to the rear of the wall outlet I've installed. I'm using RG6, BTW. The splitter installed by the cable company shows to be -3db for each of its two outlets. I cannot find a 3-way splitter to replace that existing 2-way that doesn't show a -7 db or greater loss.
    Here's the questions:
    1) Is there a 3-way splitter available that has only a -3 db rating for each outlet? If so, where can I find it? This is my first preference.
    2) If there isn't one, can I use one of those less sensitive splitters and not experience a visible drop in PQ?
    3) How does a signal amp work? If I have a significant loss of db at the splitter, will the amp return the signal to its original form, ie. no data lost?
    Thanks gang.
    There aren't any splitters that have lower insertion losses. As you've found it's either -3dB or -7dB, those are the only choices.
    An amp simply boosts the existing signal, noise and all.
    Start by removing the existing splitter and put in one 3 or 4 way splitter. Then see how the picture looks throughtout the house. Add a signal amp if needed.
    Another option is have the cable people increase the gain to the house. Unfortunately alot of cable companies don't like to do that.
    • Uncle Clive
      Former Moderator
      • Jan 2002
      • 919
      Why not use a second 2-way splitter then? Disconnect one of the outputs from the existing and add a very, very short piece if cable between that output to the input of the second (new) splitter, then reconnect the one cable to one output of the new splitter and connect the new cable run to the other :W
      GOOD TO GO!!!! :T
      CLIVE
        Hey Uncle, how ya doin'?
        I'd really rather not add splitters if I can avoid it. That'd be another 3 or 7 db drop, plus the extra interference from the added cable-to-splitter connections.
        Unfortunately, I've not found a single 3-way splitter that is -3 db. I've found lots of -7 db ones though. :evil: I'm going to keep searching for a few more days. Here's hoping. . . .
          Nor will you. A 2-way split is -3dB. A 3-way split requires a bigger drop on each leg. Most 3-ways are wired internally just like two 2-ways daisy chained. So, one output is -3dB and the other two are -6dB. The best thing might be to use two splitters and send the stronger signal to the component that needs it most. A 3-way would do the same thing if the outputs are clearly labelled so you know which is the stronger but that's often not the case. DIY with two 2-ways leaves no question about which leg has the stronger output.
          • willng24
            Powered Coax splitters, any good??
            by willng24
            Hi All,
            I live in a high rise building and it is common to see coax cable being split throughout the building. Just in my unit alone the coax is split 3 ways (two bedrooms and living room). Would using a powered coax splitter improve my picture quality? I guess my true question is,...
            08 March 2006, 16:08 Wednesday
          • ajpoe
            DAC1 and splitters
            by ajpoe
            Will using a high quality splitter degrade the sound quality of what's coming out of my DAC1? I would imagine no... The reason I ask is that I run the optical of my soundcard from my HTPC to my DAC1 and then to my 1068 in Bypass. I have a long run of RCA from the analog out on my soundcard to a bedroom...
            08 August 2005, 14:56 Monday
          • raysam
            RSP 1570 and HDMI splitter
            by raysam
            Has anyone found a HDMI splitter that works with the RSP 1570?
            I’ve tried both Audio Authority’s and Gefen’s 1:2 HDMI splitters and both exhibit various handshaking problems, where one or both displays will not display correctly.
            Both splitters work well when splitting...
            18 November 2009, 14:09 Wednesday
          • raysam
            Problem with RSP-1570 with HDMI splitters
            by raysam
            Has anyone found a working HDMI splitter that works with the RSP-1570? I bought the Gefen 1:2 HDMI splitter and I seem to get a "yellow hue" on any analog source that is converter to the HDMI output, including the boot up menu screen. The image itself is correct but any white...
            15 October 2009, 17:31 Thursday
          • safaa426
            can i use vga splitter for dvd player?
            by safaa426
            hello every one , i`m new here.
            i just have a Q,
            can i use vga splitter to split a component signal from dvd player using powered vga splitter.
            the reason is i want to drive the sony tv and panasonic pj at same time,using a dvd component signal.
            if this is possible...
            28 December 2004, 01:05 Tuesday
