Anyway...
I just finished building a pair of Finalist speakers found in the DIY section and now need a nice 2 channel amp. Since the Finalists are rated as a 6 ohm speaker with dips down to 4 ohms and only a 83dB sensitivity rating these are hungry speakers. A high current design with a minimum of 150W/ch is required. I want to buy this amp ONCE and not look back. However, funds are an issue (when aren't they?) so I am looking for used pieces. I have narrowed my choices down to the following in basic order.
Odyssey Stratos [150W/ch] : $1275 new without any factory tweaks
McCormack DNA-1 [185W/ch] : $800-1000 used
Bryston 4b (st and newer versions are still too pricey) [200W/ch] : $650-850 used
PS Audio 200C [200W/ch] : $550-800 used
Onkyo Integra M-504 [165W/ch] : $500-700 used
Adcom GFA-555 mk 1 [200W/ch] : $300-500 used
So, has anyone personally listened to any of these? What are your thoughts?
unk:
these are the impressions that I have received: Bryston is slightly bright, built like a tank, and best in warranty. Classe is more refined, softer in sound, close to tubes. Emotiva hits like a tank, good deal for the money, cold and bright. Krell is overbuilt, emphasizes the lower register to the detriment of everything else. Adcom is a good place to start for not a lot of money, sounds grainy and bright. I know absolutely nothing about Aragon....hmmmmm.
ops:
