Looking for CD player help....
  • Finleyville
    • 350
    Anyway...
    I have been using the same Denon turntable CD player for 20 years and it finally gave up its ghost. So I need a replacement.
    I am looking for a turntable unit to hold about 5 discs. A half decent DAC inside would be a bonus (in other words not a 1-bit player.) I have been out of the loop for a while now so I have no idea what might be out there.
    Oh yeah, cost. I don't want to spend more than $400. $500 max if it is the bomb. Used is fine too.
    Hi Michael!
    Great to hear from you!
    The Wife often asks if you have been around.
    Hope you are well.
    Sorry but I have no help to offer regarding a multi-disc player, but.....
    Check your mail, I have a PM for you.
      • 16128
      OK don't know of any upper end disc changers.
      • madmac
        • Aug 2010
        • 3122
        Get a Marantz turntable CD player. I have the old Marantz CD63SE single disc player but I heard that you can get a similar unit with multi disc format. Obviously, the 63SE unit is not available anymore but I would bet there is a new evolved player that's probably even better.
        Dan Madden :T
        • Glen B
          • 1106
          The Marantz CC4003 5-disc carousel CD changer is right on your budget at $399.00 MSRP.
          Marantz CC4003
            Also, you might consider taking it to the shop, Vintage HiFi of Pgh, to see if Tom or Anders can resurrect it. They may even be able to mod it. If not, Tom may have some used multi-disc units there. I would wager a cold case of Leffe he does. In the price range you mention you could likely get a used unit, have it modified & still have $ left for plenty more new music.
              ehw...that looks nice for the price........
              • Finleyville
                • 350
                So after some research I found these. All have a 24-bit dac and can play cd-r's.
                Marantz CC4003 $200 used auction
                Denon DCM-460 $100 used auction
                Onkyo DX-C390 $100 used auction
                Sony SCD-C222ES $140 used auction
                Sony SCD-CE595 $95 used auction
                Both Sony's can play SACD's.
                I like Denon/Marantz equipment. However, the Onkyo has my interest right now. SACD would be cool but I am leaning towards a future home server anyway. What do you think?
                • madmac
                  • Aug 2010
                  • 3122
                  SACD and DVD-A are basically dead mediums now. I wouldn't worry about that format. I would as a first choice go with the Marantz line but denon is good also. Walk away from the Sony's and Onkyo's.
                  Dan Madden :T
                  • Westly197
                    Pioneer Elite DVC36 or Sony DVP-CX660 5 disk changers?
                    by Westly197
                    Which DVD should my friend get?
                    Pioneer Elite DVC36 or Sony DVP-CX660 5 disk changers.
                    A friend wants to get a new 5 Disk DVD player, he has a Mitsubishi VS-50703. The VS-50703 has component video inputs but is not compatible with progressive signals.
                    The reason...
                    24 January 2001, 11:40 Wednesday
                  • 32Deus
                    Looking For RD-2200 Cassette Player
                    by 32Deus
                    Hi have been hiding in the background on this forum for what seems forever and have finally stuck my head out! Looking to replace my RD-2200 Player that some lowlife stole whilst my wife and I were away on holidays. Have been able to replace the amp (RB 5000) the Linn turntable (no Grace arm or Cartridge)...
                    20 January 2016, 19:39 Wednesday
                  • rick c
                    adding turntable to rsx1056
                    by rick c
                    I have a turntable that i would like to use w/the rotel.I know that i would need a phono amp.My question is where would i connect the phono amp to on the rotel.Right now the functions on the remote are pretty used up.I have sat/hdtv to v1,dvd to v2,vcr to v3,playstation to v5, v4 is not being used right...
                    02 November 2004, 13:01 Tuesday
                  • Horacio
                    Does it makes sense to add turntable?
                    by Horacio
                    I own a Rotel CD player, pre amp, and power amp, but no turntable or vinyls. I hear vinyls have now as good a sound quality as CDs do and are significantly less expensive. Any truth in this tale? Would you add a turntable?
                    Thanks folks,
                    Horacio
                    29 January 2005, 18:09 Saturday
                  • GregoriusM
                    Kenwood DVD/CD Mega Changers
                    by GregoriusM
                    Has anyone seen the specs on the new Kenwood DVD/CD mega changers due in Aug/Sept. AWESOME!
                    Check out this thread on Remote Central and scroll down to my links, and check this puppy out.
                    I'd like to hear what you think of it.
                    It is in the Sovereign line-up...
                    07 June 2001, 01:57 Thursday
