Multi room question
  • agrippa
    • 199
    Multi room question
    I am not sure where I should post this but here it is.
    I want to add one room to my current setup.
    I have a high end Denon receiver in my Home Theater setup. I want to add a rec room which isn't far away.
    I still want to have home theater sound in the one room but just stereo sound in the rec room for music.
    here is my one idea so far http://www.amazon.com/Monster-SS-6-S...=2OS99MAW4VCHF
    Does anyone have a good recommendation for a cheap quality speaker switcher?
    Or do I have to make some simple switch?
    Lady Nancy Astor: "Winston, if I were married to you I'd put poison in your coffee"
    Winston Churchill "Nancy, if I were married to you I'd drink it."
    Well, the absolute easiest thing would be, does your Denon receiver have a "2nd room" feature? Most good receivers nowadays do, where it acts like a 2nd receiver inside the box, selecting and outputting audio (and sometimes video) to a 2nd room. Sometimes you can even get it to put out amplified audio to the 2nd room speakers.
    Then you wouldn't even need any new components, just use what you already got.
    • Kevin D
      • 4601
      If you don't have a Zone 2 like Chris suggested, the problem with doing it the way you want to do it is, you'll have to set the Denon to stereo or 5ch stereo everytime you want to listen to the other area. Otherwise, any important signal information going to the center channel will not be heard in the other room.
      Plus, room/speaker differences considered, you might find that to get the rec room loud enough will require blasting the main room. So if you had to go this route, look for a speaker switcher with volume controls built in. The does present another problem in that the volume control will not effect the other speakers in the surround room nor the subwoofer.
      So post up the model of your Denon and we can tell you the best route to take.
      Kevin D.
      • agrippa
        • 199
        Denon AVR3802... It is over a decade old. Most likely not the top of the line any more.
        Here is a like to the owners manual.
        http://usa.denon.com/DocumentMaster/...nersManual.pdf
        We intend on only listening to music in one room at a time. not both. I also don't mind having to switch between 5 channel and 2 channel, if that is what it takes.
        • Kevin D
          • 4601
          If you are just using 5 speakers in the surround room, I think you are in luck.
          Hook the new set of speakers to the center-back/multi speaker outputs.
          Then check out page 10:
          Set Power-Amp assignment: Multi
          Page 15:
          Set Multi-vol level: Variable
          Page 26:
          Controlling the source and volume for the second zone.
          Also note that only analog sound will be available on the multi-zone speakers. So if your DVD/CD player is only hooked up with a digital cable, you will need to run analog cables to the analog inputs as well.
          Kevin D.
            Ask the forum here, and you shall receive....
            • agrippa
              • 199
              I will give that a try, thank you. It may be a couple weeks before I get to it. I am redoing everything audio related in our house. If it doesn't work I will be back.
              Thank you again.
              • rman01138
                Denon AVR-5308CI
                by rman01138
                Does anyone own this reciever. I need a second opinion. I would like to buy this reciever for the features and use a Rotel RMB1095 to output the sound. Here are some specs.
                Details:
                150 watts x 7 into 8 ohms (20-20,000 Hz) at 0.05% THD
                THX Ultra2 certification...
                17 February 2008, 22:32 Sunday
              • P-Dub
                Calculating room volume?
                by P-Dub
                Well, in a nicely closed off room, that's easy, LxWxH. But what about the various opennings? At what point do you say, enough is enough?
                Take for example a house I'm looking at renting. The main living room is nice and large, I'd estimate a 24ft x 18ft x 8ft room. But it's not closed...
                14 June 2002, 15:32 Friday
                Making a central electronics room for the house - my equipment rack pictures, too
                Okay, so I FINALLY got my new equipment rack 99% set up in my new house, with thanks to help from the Parasound guys! (I couldn't find my HRA-4u Halo C1 rackmount ears after my move, for one thing) First, the pic of the equipment rack itself. Wish I could post larger, more high resolution pics. ...
                24 March 2008, 02:54 Monday
              • joe_s
                subwoofer choices
                by joe_s
                I have a "rec room" that is a primary music listening room, and secondary movie room, and tied with my home theater room for TV use. I have a CA5200 with B&W 802D's and HTM2D.....some cheap in ceiling for "surround" that were installed with the house. As i have B&W in...
                28 May 2007, 15:57 Monday
              • kid320
                Yamaha RX-V1800 vs Integra DTR 6.8/7.8 for 12x12 room
                by kid320
                Hey everyone! As always, I appreciate everyone's opinions on this board. Any major home theater purchase I have made over this past 3 years has passed through this board at one point in time. So, this decision should be no different.
                I currently have a Yamaha HTR-5540 receiver. I...
                13 March 2008, 22:42 Thursday
