Hello, I just purchased a Rotel 1520 integrated amp, I am setting it up to my iMac and have ALAC files for music. Speakers are B&W CM5, my living room is about 12x13. I am looking for a DAC under 500, any recommendations? Thank you.
DAC for iMac
You might consider the Grant Fidelty Tube DACs like the DAC-09 or the newer DAC-11.
Cheers!Main System:
B&W 801D
Emotiva USP-1 Pre-Amp
Chord SPM-650 Stereo Amp
Oppo BDP-105
Squeezebox Touch
Second System:
B&W CM7
Emotiva UMC-1
Emotiva UPA-2
Oppo BDP-83SE
Grant Fidelity DAC-09
I run a Rega DAC from my Mac Mini, but there are a number of good DACs available. But for around the $500 mark, Emotiva or Audio-GD make DACs that have had good reviews.Analogue Source: Rega P1 w/ Ortofon OM30, Digital Source: Mac Mini (late 2009), PS3 -> Rega DAC -> Amplification: Rotel RA-1520 -> Speakers: B&W CM5, Wharfedale SW150- Bottom
by JonMarshThe Calliope uses the DA25TX; we've used that in several designs. It's a real bargain in the performance/cost ratio; it's drawbacks are mainly the large size and flimsy front plate- I've actually dissembled these on occasion and epoxied two front plates together and re-assembled the tweeter with one...-
Channel: Digital Audio
by wettouWhy Use a Better DAC?
An argument for why using an external audio converter IC over one integrated on an SoC can help ensure high-quality audio performance.
By Dafydd Roche, Texas Instruments
My system-on-chip already has an onboard codec. So why should I bother...-
Channel: Club Classé
04 December 2008, 12:37 Thursday -
by mb225Does anyone have experience with external DACs? My current system is great but I still find it to be edgy or bright sometimes. I’ve been reading a lot of reviews on DACs lately and I was wondering if that should be my next upgrade? A lot of the reviews of DACs seem to address jitter and use phrases...-
Channel: Audio Hideout
by Brandon BPosted what I thought was a simplified explanation about sound quality in DD/DTS vs. PCM. Curious where I'm off vs. maybe the guy correcting me.
My post:
The response:
My followup:
Some more expert...-
by audioquesoTest Setup:
Speakers: B&W Nautilus 805
Integrated Amp: McIntosh MA6800
Source 1: HTPC w/ RME Hammerfall 9632 Soundcard
Source 2: HTPC w/ Musical Fidelity V-Dac (via USB)
Source 3: Marantz DV6001 DVD player w/ MF V-Dac (via digital coax)
* All sources...26 July 2009, 17:49 Sunday - Loading...
- No more items.
