Audio showroom size
  • GregLett
    • 755
    Audio showroom size
    I have a question for my fellow audiophiles.
    What would you consider a perfect size for a showroom?
    A size that would serve well for both stand mounted as well
    as floor models. I know there will have to be a comprise.
    I was thinking about a 20X30 or 20X14
    Greg
    20x14 is a decent size for a private dedicated theater, but if you're looking to do an actual showroom, you probably want a bit bigger, mostly in width. 20x30 would be more than you need.
    • GregLett
      • 755
      Thanks Chris.
      Greg
      • RobP
        • 4747
        Play around with this calculator and see what your different room sizes will yield.
        Robert P. 8)
        AKA "Soundgravy"
        • GregLett
          • 755
          Robert that's very interesting calculator. If I understand what I am seeing, it looks like a 24 x 16 room is a good size. My plan is to build a room in my backyard. I have room for the length or width depends on how you look at it to be as much as 24', but the other dimension can only be up to 18'. I don't want to get too close to the deck.
          Greg
          • dknightd
            • 620
            Is this a showroom for personal enjoyment, or, for selling things in? How many people should it seat? How big a screen? If you are building from scratch you should keep in mind room modes.
            • GregLett
              • 755
              I's for selling two channel only audio and personal enjoyment. I don't want someone to walk in and feel cramped, I have been in a few of those.
              It's going to be built from scratch. The max dimensions can be 24 x18.
              Greg
              • twitch54
                • 340
                Given your "Max" #'s ......16' wide, 24' deep, min 10' ceiling ht. That way your Logans can be the ideal 4-5' out from the walls.
                Dave
                • dknightd
                  • 620
                  24x13x9 looks pretty good
                  • GregLett
                    • 755
                    I have to go listen to the Roger Sanders speaker. That could wind up in there, or if ML likes my room a pair of summits
                    Greg
                      hey that calculator predicted my rooms dip at 63 hz - it works....I think
                      Mind you there is a dip and there are spots with reinforcement also - how did it know that the dip is at my listening position I wonder. I will have to go back and have a closer look at that calculator.
                      • twitch54
                        • 340
                        Better yet............ how about a pair of CLX's, assuming they are introduced later this year.
                        Regardless of what the other poster said (13' width), DO NOT go less than 14-15' for speaker(size and type) would then be limiting.
                        Dave
                        • GregLett
                          • 755
                          I wouldn't go less than 16'. My current room is 11x14 by 7' high, so I will build something bigger. I'm thinking about putting monitors in my current room once the other room is done.
                          Greg
                          • RobP
                            • 4747
                            24 X 16 looks pretty good, now if you could go with an 11' ceiling that would be icing on the cake. For me that would be the optimal size room. You could host a variety of different size systems in that space.
                            My room is 21.5x 13.8 x 8 and I think that the side walls are a bit too close, I agree that staying wider than 14 would be ideal if you can do it.
                            A dedicated outdoor building will be nice, heck I am in the planning stages myself for an outdoor studio for my work, maybe it can be a listening room too :twisted: .....although, I don't know how much work would actually get done if I did that.
                            Robert P. 8)
                            AKA "Soundgravy"
                            • GregLett
                              • 755
                              What I looked at so far had a height of 8' at the end and sloping up to I think 12 feet at the center. I was thinking of not having a flat ceiling, but to follow the slop. How does that sound?
                              Greg
                              • twitch54
                                • 340
                                Let me give you a nickels worth of advise.......... go over to Audiocircle.com and under the sub-forum "acoustic circle" you can pose your room design questions to the many qualified folks that are regulars there, like Ethan of Real Traps , along with Glenn and Bryan from GIK.
                                Also, be sure to check out "JonFo's" Thread on the Martin Logan forum regarding all his excellent room acoustical work.
                                http://www.martinloganowners.com/for...ead.php?t=5435
                                the more optimal the initial room design is the easier it will be to acoustically treat !
                                Dave
                                • RobP
                                  • 4747
                                  I have seen a few rooms with a sloped ceiling, although I have never listened to them, that type of design is used in large areas such as concert halls and such, but Im really not sure if it would apply to a small room, trying to calculate modes in that scenario will be very tricky.
                                  Just another option that may actually work better for you would be to hire an acoustical design consultant, there are companies such as Rives Audio who can help you plan your room, they have several different levels of design that they offer to fit your budget.
                                  If you decide to go it on your own then I would suggest picking up a copy of The Master handbook of Acoustics, its a wealth of information and is a great reference and will serve you well in your room design.
                                  Also, I don't like pointing you away from our site for info, but this site is run by people who actually do this type of thing for a living, although the emphasis is on studio design, the concepts and information can be used in a listening room setup.
                                  Robert P. 8)
                                  AKA "Soundgravy"
                                  • RobP
                                    • 4747
                                    Couldnt agree with you more, although with a well thought out plan, the treatment can actually become part of the room, which would be pleasing to the eye as well as to the ears.
                                    With a plan like Gregs, he could easily build his bass traping into architectural features such as soffits and columns, diffusion could be built into the walls so as they would almost become works of art, with his clean slate, the possibilities are only limited by his imagination.
                                    Robert P. 8)
                                    AKA "Soundgravy"
                                    • twitch54
                                      • 340
                                      Yes Robert I agree, FWIW, I was not trying to 'derail' Greg's thread, it's just that there IS very good and in depth discussion on other sites. Also Greg is a Martin Logan owner as am I, and my refrence to a thread on the Logan Forum was for informational purposes on thread that a well respected member of our group has ongoing.
                                      Dave
                                        Huh... that IS a very interesting website. Now I just have to figure out what it all means...
                                        • GregLett
                                          • 755
                                          Thanks for all the input guys. My first task is to get the structure built without getting soaked. Wood structures are expensive.I am looking at a steel exterior as an option. Due to how they make the steel the structure increases in 5 foot increments. So I'm looking at a 25 x 20 structure. The height is 10 feet.
                                          Greg
                                          • RobP
                                            • 4747
                                            I hope I didnt make it sound like you were, my apologies Dave.
                                            Robert P. 8)
                                            AKA "Soundgravy"
                                            • twitch54
                                              • 340
                                              Thanks Chris ! We M/L folks get a little fanatical at times !
                                              Dave
                                                ah, sorry... actually, I meant the website calculating the room nodes. I plugged in my theater room values, and got results (that don't look too terribly bad) but don't know how to interpret all the numbers and stuff on the page...
                                                • co64
                                                  803D and size of room
                                                  by co64
                                                  I have been reading concerns over speaker selection and room size. I'm considering using 803D's as a part of a HT in a dedicated media room. 20x14 ft completely enclosed. After listening to 804S thru 802D's at my local dealer, I loved the sound of the 803D's (powered there by McIntosh monoblock...
                                                  30 November 2009, 16:49 Monday
                                                • xbliss
                                                  Pls Guide: 4K TV: Size, Mount, Ideas - Tilted Angled Down, Corner, Flush to wall
                                                  by xbliss
                                                  Pls Guide: 4K Display TV: Size, Mount, Ideas - Tilted Angled Down, Corner, Flush to wall
                                                  Please advise on 4K Display TV - Size + Mount & mounting ideas - Tilted Angled Down, Corner, Flush to wall
                                                  Suggestions on TV size & Mounts/ ideas on designing & implementing...
                                                  10 March 2016, 04:27 Thursday
                                                • kcsun
                                                  Speaker size = room size?
                                                  by kcsun
                                                  Please can someone enlighten me?
                                                  Whenever you go to a Hi Fi shop and say you are interested in a new pair of speakers, the salesman will ask what your budget is, what colour you would like, floor or bookshelf and if he is on the ball he will ask what amp you are running and your musical...
                                                  25 June 2012, 15:28 Monday
                                                • gobblyguk
                                                  speaker driver size
                                                  by gobblyguk
                                                  Hi folks.
                                                  I've been checking out these forums the past month and getting a great education. I am presently building a home theatre room in my basement (13x17x8 ) and I have a fundamental question I'm hoping someone can answer.
                                                  I am presently searching for a 5.1 speaker...
                                                  01 April 2005, 08:40 Friday
                                                • corysmith01
                                                  Speaker Cable Lug Size for Rotel RSX 1056??
                                                  by corysmith01
                                                  So, I finally (after 3 years) was able to procure my first piece of Rotel. I bought a used RSX-1056. I run HDMI straight to my tv so having it on the receiver is of no use to me. So, I figured while I could catch a deal on a 1056, why not? I've had it for a week and am loving it. It replaced a Denon...
                                                  04 October 2007, 16:14 Thursday
