Advice: Stress tests for amps? problems with H/K avr635
  • jquin
    • 138
    Hi All
    I have a H/K AVR635 that has been causing some concern. I have had it in for repair only to have a "nothing is wrong" verdit.
    The problem is that the system sounds fine with music esp. HQ recordings but
    for speech it gives distortion. Well it sounds like distortion to me.
    The issues is esp during words like "are" the resonance in the "rrrrr" part seems distorted like it's clipping or something.
    I have noticed this with three different pairs of speakers, the current ones being my build of Jon marsh's ModulaMT.
    Does anyone know of any stress tests for amps so that I can give the "technicians" something repeatable to test against. The warranty runs out soon so I'm keen to get this sorted.
    I have some test equipment, I'd just like a pointer or two from wise amplifer gurus' ;x(
  • dknightd
    • 620
    If it sounds fine with some things, but not others. I'd suspect the recording, not the amp.
    I've never heard of an amp having problems with r's
    If you have something that clearly demonstrates the problem, you might want
    to try it on other amps, and perhaps other rooms, to see how it sounds there.
    Therrre arrre no strrress tests that I know about that would identify a prrroblem with rrrr's. I wonderrr if yourrr earrrs have an issue with rrr's.
    Did you ever run a jack hammerrrr?
    • jquin
      • 138
      Gee thanks, that was VERY helpful :roll:
      • JudyLou
        • 69
        Hi SHLM jquin
        We had a similar problem on a Marantz receiver a while back. But our problem only arised when we played DTS formatted DVD’s and only the surround channels. So they replaced the processor DSP chip and problem was solved. I “apparently” had to do with certain frequencies in a certain range that when to the surround and rear channels.
        Now I don’t know if your HK does it in all formats and on all channels – but it also sounds like a processor problem – if your amp is the problem!?
        Also, just check your interconnecting cables from your DVD/CD player – if its not the cable try chancing to another input, like if its now on the DVD input, move it to the CD input.
        Always first start on your source and move down along the line to eliminate where it might come from.
        Good luck
        BRK
        Lourens
        • jquin
          • 138
          Thanks alot. It nice to hear that other have had similar problems.
          I'll try to monitor the line outputs to see if the issue is there.
          • Scarp
            Audio Meeting At My Home
            by Scarp
            Hi Guys,
            On a dutch Home Theatre forum we decided to do a little meeting and amplifier shootout. We did that last year at someone else's house and this time they came to my house. Yes, a fortune of amps at my house
            So, whats the idea... a few people get together and...
            01 March 2004, 16:15 Monday
          • tbyrne
            Can I wire two amps (to be used alternatively) to B&W 684s?
            by tbyrne
            I have a six year old Marantz SR4300 HT receiver which works fine as a HT receiver, but seems a bit underpowered for my new B&W 684s. Actually, I think the Marantz eventually makes plenty of power, but I really need to turn it WAY up to get it to play loud (from its baseline –72 db to about –5...
            28 January 2008, 11:02 Monday
          • jazznsoccer
            Rotel 1095 Amps & B&W802 = biamping make a difference?
            by jazznsoccer
            Hi All,
            I demo'd B&W speakers and settled on the 802's (higher up was beyond my point of pain for speakers). I really liked the 802's over the 803. Alll tests were done using the Rotel RMB-1095.
            I've heard that most people would suggest getting a better amp, but there...
            30 April 2004, 23:36 Friday
          • Mark K
            New 7" driver tests
            by Mark K
            Something to digest.
            New 7" tests.
            some interesting tests on the peerless hds exclusive and more.
            http://www.markk.claub.net/...
            02 February 2007, 01:26 Friday
          • augerpro
            Assorted driver tests
            by augerpro
            Hi everyone. I've just finished some driver tests and put them up here:
            Images not available
            just look in the albums with the blue names, all the rest on the main page is just my junk.
            The FR plots are 1/24 smoothing so they are a little unforgiving. Gate was 7ms...
            30 April 2007, 02:16 Monday
