Hi everyone. I've just finished some driver tests and put them up here:
Images not available
just look in the albums with the blue names, all the rest on the main page is just my junk.
The FR plots are 1/24 smoothing so they are a little unforgiving. Gate was 7ms for farfield and 200ms for nearfield. The shaded are means the data is invalid.
The THD lower frequencies aren't quite as smooth as Zaph's. I think he uses a higher sampling soundcard though, so that may be why. If you look at the RS150 and 832873 plots they follow Zaph's quite well. It took alot work to get that let me tell you! But I'm pretty confident in the plots now. Please look at the Baffle effect jpg first so you can see what the effect is on the FR. Tweeters aren't really effected here, but the woofers are at lower frequencies. Tweeters were level matched using white noise, and woofers were matched using pink noise at .5 meter. This level is in the file name. There is a room effect at 120-140 Hz. If you guys catch any others let me know, I didn't see anymore though.
I haven't really analyzed anything yet but from a quick glance the Goldwood GW1258 and Selenium didn't do that bad in THD. CSD wasn't too good I don't think and the Z plot is kinda scary. Alot of cone breakups going on I think.
And the Scanspeak 9800 impressed me. Look at that FR! Flat to 1000Hz! Impressive. Now at first glance you may think the lower end distortion is higher on the 9800 vs the Peerless HDS. But these plots are unequalized so the HDS appears lower. If they were equalized i would say the 9800 is slightly higher in 2nd harmonic distortion and lower in the higher orders in the <2000Hz area. Anyone agree? I am reading that graph correctly? One thing you can't see is the higher spectrum noise I see during the sweep. Basically it looks like MarkK's multi tone plots. Here the 9800 was lower in noise than the HDS. Although I don't knwo how important taht is given those frequncies are well above 20k anyway.
Let me know what you guys think of these tests. If you have any advice I'd love to hear it. Also some pro's evaluation of the results would be helpful, especially the proaudio drivers. Over the next couple days I'll be adding some more drivers, particularily some HiVi M and B series drivers, and some small MCM drivers.
EDIT: during the Goldwood and Selenium test the mic level maxed adn clipped above 2000Hz. It's pretty obvious on the plots. So I ran another plot just from 2000-5000Hz with the mic gain down. Also the Goldwood 1258 Q was .48 and the Selenium 10PW3 Q was .71
