805 matrix has broken tweeter - need replacement
  • jt69
    • Jan 2007
    tweeter broke off my 805 matrix and lost. Any recomenndation for repair/fix?
    who to contact?
  • dknightd
    • 620
    My first suggestion would be to contact you local dealer.
    Next would be to contact b&w. Have you tried that yet?
    There has to be a story behind breaking off and loosing a tweater.
    What is it . . .
    • jt69
      • Jan 2007
      I've hired some starving students to help moving ... after unpacking I noticed that tweeter was not there anymore ... aslkdfasdfk. Recommend any dealer in Santa Clara, CA? ths!
      • Fife
        • Apr 2004
        • 141
        Call B&W America. I think they have replacements.
        • rkburton
          Wall mounting Matrix 805 help needed
          by rkburton
          Wow! It's been a long time since I "lurked" on this forum - almost 4 years! :E
          I've ended up moving and my new HT set-up will require mounting my Matrix 805 on the rear wall for rear-fill.
          What speaker mounts would be recommended?
          I'd really prefer to attach the...
          05 December 2008, 17:08 Friday
        • remcoy
          which rotel amp for Matrix 805?
          by remcoy
          i was wondering if anyone had any thoughs on which amp might be best suited for my matrix 805's
          I have been using a 5ch RB-985 (100 watt/150 dampening factor) in combination with an RSP980 preamp for the past five years or so, but i have decided to move away from the multi channel setup...
          27 April 2005, 19:34 Wednesday
        • Celt16
          Need new electronics for 7.1 B&W Matrix 803S(2), 805(3) and DS6(2)
          by Celt16
          I'm seeking suggestions for my 7.1 home theater - speakers are all B&W, Matrix 803S fronts, Matrix 805 CC and rear surrounds, and DS6 surrounds, all bi-wire capable.
          Suggestions have included Bryston SP2 (no composite?) plus 6B and 9B
          Bryston SP2 plus Adcom 7805 + 2 similar...
          19 December 2006, 11:02 Tuesday
        • Celt16
          What electronics for B&W Matrix 803S(2) 805 (3) and DS6 (2)?
          by Celt16
          I need to upgrade my electronics for a 7.1 HT featuring all B&W - Matrix 803S fronts, Matrix 805 rears and CC, DS6 surrounds and the awesome ASW850 sub.
          I'm looking at Bryston SP2, 6BSST and 9BSST,
          SP2 Adcom 7805 & a 2-ch Adcom
          Anthem D-1
          Integra RDC7
          19 December 2006, 11:18 Tuesday
        • rontron
          surrounds for matrix 803's?
          by rontron
          Hello
          I have a pair of matrix 803's ( series one) for the fronts and a matrix htm for the center. Does anyone have sugestions for matching surrounds? I was thinking of either finding a pair of matrix 805's or perhaps the old cinema dipole i think the model was ds6. Would any of the current...
          28 January 2005, 12:03 Friday
