Pro Logic II Or Stereo
  • comeup
    • 356
    Happy new years everyone
    I'm sitting here listening to classic jazz on sirus radio on dish network switching stereo and pro logic 2 back and forth trying to figure out which one I like better. I normally listen to music in two channel, but i'm starting to like pro logic II it's so much better than the old pro logic. You can't even tell that the centre speaker is being used. These engineers are good how do you take something already in two channel and by the click of a button turn it into surround music and sound right without the sound being thrown all over the place?
    Which do you like and why?
    Blake
    I'm a bit of a purist so I prefer 2-channel, but DPLII is about the best matrixed sound I've heard.
      I too have always been a purist, listening to things only in their native formats. HOWEVER, once Parasound added DPLIIx (more than DPLII) to my processor, I found that I enjoyed it so much, now I use it for ALL my sources, whether it be music, movies, television, or even the Playstation 3.
      Dolby Labs really did DPLIIx right--I enjoy the soundfield it adds to every source, without screwing up the sound. (anybody remember the old DSP's like "Concert Hall" or "Stadium?) **shudder**
      • Kevin D
        • 4601
        Always remember to set up PLII as well. Most receivers default it to no rears and a ton of center.
        Kevin D.
        • Burke Strickland
          • Sep 2001
          • 3159
          Those old reverb-heavy DSP choices should have been labled "Shudder" -- or "Cringe", "Recoil in disgust", "Put fingers in ears", etcetera.... :>)
          • comeup
            • 356
            Originally posted by Chris D
            HOWEVER, once Parasound added DPLIIx (more than DPLII) to my processor, I found that I enjoyed it so much, ALL my sources, whether it be music, movies, television, or even the Playstation 3.
            Chris,
            whats the difference between II/x I have an B&K REF 50 with only II
            Blake
              Well, the primary thing is DPL IIx extracts everything to 7.1, instead of 5.1 with DPL/DPLII, so I get a more enveloping sound field that goes all the way around me, not stopping at my sides. As far as more technical stuff, I'd have to refer you to Dolby info, but since IIx was created after II, I would assume that it also uses improved processing for more natural sound.
                Literally. I would go to people's houses that would play things on their stereos with various DSP's, and have to leave the room. For a bit after I got my first true theater receiver, (Yamaha RX-V2095) my wife would play music with the "Party" DSP. It was painful.
                • comeup
                  • 356
                  I wonder if the B&K REF S2 has it I can upgrade the S1 to S2 I'll have to check it out.
                  Blake
                  • Kevin D
                    • 4601
                    Plus IIx can be applied to 5.1 digital sources to get 7.1 as well. I find DD+PLIIx a lot better then a true DD-EX track.
                    Kevin D.
                    • John Holmes
                      • 2707
                      Yes the S2 has PLIIx. Though I'm not sure if it would be a real benefit. Your Ref 50 will run PLII out of 1 or 7 speakers. But Chris maybe right about PLIIx having better steering.
                      • comeup
                        • 356
                        John, you know how it is, always thinking of upgrading, maybe i'll get some other features out of the upgrade.
                        Blake
                        • Jeff
                          • 281
                          Everyones comments about IIx seems to be directed towards a 7 speaker set up. Will IIx perform better than PLII with only a 5.1 set up?
                          • Kevin D
                            • 4601
                            On most systems I've seen, you won't even have an option for IIx with only 5.1 speakers setup.
                            Kevin D.
                            • Ovation
                              • 2204
                              The system will default to PLII (no "x") if the set up is 5.1. I use DPLII Movie for all my TV watching (except sports--my receiver's "Enhanced" DSP setting is quite good for hockey games). I use DPLII Music for casual listening of the music channels on my cable box (they are broadcast in Dolby 2.0) but I don't usually listen to DPLII Music with my 2 channel sources. I prefer discrete to matrixed MCH with music for critical listening.
                                • 1933
                                My tv audio is always set to DPLII. My setup is not 5.1 or 7.1, but it still sounds better for an audio from my Directv.
                                  Twin Moderator Emeritus
                                  • 16706
                                  I tend to use use DPLII for non critical listening (up and about doing chores etc) but stereo when I'm doing serious listening. I've found some discs sound better/worse with DPLII so it requires some experimenting too.
                                  • John Holmes
                                    • 2707
                                    Yes you will! :B Including PLIIx. But since this is a thread about DPL II/IIx vs. stereo , I'll just leave it at that.
                                    • clearwaterms
                                      • Nov 2006
                                      • 110
                                      I used to listen to my music through the cable box on the PII music setting alot, however now I just listen in stereo. I found that the music setting is great only if you are sitting in the (forgive my incorrect terms) 'sound pocket' that exists when you are between the left and right channels. and often times I listen to music while doing something else which puts me in and out of that 'pocket' and the vocals seem disconnected.
                                      • chinets
                                        • 855
                                        I personally prefer the Pro Logic II over stereo ,especially when watching satellite T.V., or when you play a CD and are listening to the music while talking to friends etc.... but for serious Music audition sessions ,Stereo No doubt!!
                                        Cheers!
                                          No doubt! :T
                                          • mitch57
                                            • 429
                                            You use DPLIIx even when you play a DVD decoded in Dolby Digital? I don't see how/why DPLIIx would be better then the original sound track. I always assumed DPLIIx was primarily used to take two channels and discretely separate them into 5.1 or 7.1. If the recording is already discretely recorded with 5.1 why would you use DPLII or DPLIIx over the original? I would think it would sound worse. But then I don't know that much about the two formats to make any informed judgments on either one.
                                            Anyone care to educate me or point me in the right direction?
                                            Mitch
                                            :stupidpc:
                                              Sure, Mitch. Yes, I do use DPLIIx for all audio formats, and yes, that does include Dolby Digital. Taking something encoded in 5.1, I have not noticed any degradation (or for that matter noticeable modification) of those 5.1 channels when using IIx. However, DPLIIx takes ***ANY*** sound format you throw at it, and extracts it to my 7.1 theater system. So by using it with DD (or DTS) I get it additionally matrixed to my rear two channels to get 7.1. The sound field becomes just a little more immersive, so instead of wrapping from the sides of my head forward, giving me 180 degrees of sound from my head like I'm sitting on the edge of the soundfield, I now get ***360 degrees*** of sound around me, placing me right INSIDE the soundfield.
                                              I become more immersed and engrossed in the media, whether it be movie or music.
                                              • mitch57
                                                • 429
                                                I see. But there wouldn't be any advantage in a 5.1 setup to use DPLIIx since I don't have the extra two speakers correct? On the other hand, if I did have the extra two speakers it might be another story.
                                                Mitch
                                                :stupidpc:
                                                • Club1820
                                                  • 269
                                                  Kevin D.
                                                  Kevin, how would you go about setting this up on the Rotel Pre/Pro 1068? I set my speaker levels with the test tone and RS SPL meter. Is this not sufficient? Or do I have to do something else for the PLIIx mode to be correctly set up?
                                                  Thanks.
                                                  Rotel 1068, Rotel 1060, Rotel 1055, Rotel 1095, Rotel 956, Rotel RLC-1040, M&K VX-860 Sub, Whatmough M30s, Squeezebox 3
                                                    Right, Mitch. If I only had a 5.1 theater, I wouldn't bother using DPLIIx with DD or DTS material. For that matter, I wouldn't use ANY processing with something 5.1 if I had a 5.1 theater, other than maybe THX equalizing. Once I get equipment that can use true 7.1 audio from the new HD audio formats, I won't be using any processing on the 7.1 audio.
                                                    The only reason I use DPLIIx right now is to get 7.1 audio out of any audio that I play.
                                                    • Kevin D
                                                      • 4601
                                                      Thanks.
                                                      You need to go into the setup menu, under input. Set the default sound mode to PLII Music, then you should have a new item called 'options'. This lets you turn on the rears, set the depth, and the center width.
                                                      Kevin D.
                                                        Building a new DAW (Digital Audio Workstation) based around 2014 Mac Pro
                                                        As I mentioned recently in another post I'm putting together a new DAW (well, actually it will be used for more than that, but the DAW aspect is a big part of the configuration choice, particularly as regards storage and connectivity).
                                                        Because of the extensive experience I have with...
                                                        21 December 2013, 12:54 Saturday
                                                      • Chris CRt
                                                        Dolby DPLIIx Upgrade - Do you think it will have this?
                                                        by Chris CRt
                                                        I found this on the Anthem forum for their D1 unit, and it appears they just got the DPLIIx upgrade (sigh). It's in "beta" format, but here's the list of what they get in the upgrade:
                                                        "Changes from v1.03 to v1.04x:
                                                        1. Added Dolby Pro Logic IIx
                                                        2....
                                                        30 October 2004, 23:56 Saturday
                                                      • macman
                                                        RSP-1098 and factory installed DPLIIx?
                                                        by macman
                                                        Anyone heard when Rotel may start shipping 1098s with Dolby Pro-Logic IIx from the factory? I'm ready to purchase, but I'd like to avoid the hassle of needing to upgrade right after my purchase, if I can. Now that the 1068 was introduced with DPLIIx from the factory, maybe the 1098 will follow soon?...
                                                        30 March 2004, 22:39 Tuesday
                                                      • Chris CRt
                                                        DPLIIx Settings and Room Sizes - Just Checking!
                                                        by Chris CRt
                                                        Hello!
                                                        I was just curious to see what you all are doing in the setup menu for Dolby Pro Logic IIx and what size your room might be. I've been playing with the settings for a little bit now and am starting to find how each works (good and bad) with the signal.
                                                        I can definitely...
                                                        21 March 2005, 22:28 Monday
                                                        New 9.1 channel Dolby Pro Logic IIz
                                                        From a news release I just saw of the first receiver, (Onkyo) with the new Dolby Pro Logic IIz technology that extracts to 9.1 channels. I chased down this technology report on the Dolby website. Very interesting.
                                                        I'm surprised that I hadn't heard of this before! My thoughts in another post...
                                                        12 March 2009, 07:06 Thursday
