Well I just recently added a few absorption panels from ATS Acoustics (3) 2'x2'x4" & (1) 2'x4'x4". The build quality is outstanding & their fabric choices are pretty extensive. These new panels combined with my GIK monster bass trap (1) 2'x4'6" & the Echo Busters corner traps (2ea) have really put a smile on my face. It's so hard to believe what actually happens. The music just takes on a whole new presence, the bass is just so damn tight now I can hardly believe it. My friends actually checked to see if my SVS sub was on. They couldn't believe it either. The vocals & instruments are so well defined & the soundstage has taken on a whole new dimension. I'm telling you if you've never thought about treating your room - mistake - BIG MISTAKE!!! It has got to be the best bang for the buck you can possibly spend. Forget about new cables, IC's, power cords, just get involved with your room. By the way ATSacoustics.com is the most reasonably priced company I have found to date. They only do absorption panels but are working on bass traps. They also sell all the material for the DIY crowd. But for me they were so cheap it didn't make sense to go the DIY route. Just do it!!!!
ATS Acoustic panels / superb performers!!!
Tags: None
Originally posted by pearsall001Well I just recently added a few absorption panels from ATS Acoustics (3) 2'x2'x4" & (1) 2'x4'x4". The build quality is outstanding & their fabric choices are pretty extensive. These new panels combined with my GIK monster bass trap (1) 2'x4'6" & the Echo Busters corner traps (2ea) have really put a smile on my face. It's so hard to believe what actually happens. The music just takes on a whole new presence, the bass is just so damn tight now I can hardly believe it. My friends actually checked to see if my SVS sub was on. They couldn't believe it either. The vocals & instruments are so well defined & the soundstage has taken on a whole new dimension. I'm telling you if you've never thought about treating your room - mistake - BIG MISTAKE!!! It has got to be the best bang for the buck you can possibly spend. Forget about new cables, IC's, power cords, just get involved with your room. By the way ATSacoustics.com is the most reasonably priced company I have found to date. They only do absorption panels but are working on bass traps. They also sell all the material for the DIY crowd. But for me they were so cheap it didn't make sense to go the DIY route. Just do it!!!!- Bottom
The GIK monster bass trap is very well constructed. The only downside with the GIK products is the cost for custom fabric. If the stock fabric meets your needs it's a huge savings over their custom colors. Echo Busters corner traps seem to be well constructed also, although it is a totally different design & size. They also have a very extensive fabric selection. For a huge fabric & an extensive product selection check out Acousticalsolutions.com- Bottom
heck yes please post some pics.. Sure do wish you had a few of the Tri Traps to show off. :B :T
GlennGlenn Kuras- Bottom
