Room treatment for Dipole
  • howburger
    • 44
    I just put three Hawthorne coaxial dipole OB's into my theater. I have 2 2" OC 703 2 X 4 panels (ATS Acoustics Panels) on each side wall, three along the back wall, and have three left to put on the ceiling. My room is 12' X 20'. I will also be stacking cut triangles of rock wool in the front corners as bass traps. I planned on tube traps, but no room. As far as I've read, the conventional wisdom seems to be that the front wall should be dead and all other walls to at least absorb the 1st, 2nd and 3rd reflections without over deadening so as to keep the music as lively as possible. BTW, I am trying to optimize for music and take what I get for HT. Does this all still apply for dipole LCR speakers? I know that to really do this right, a professional acoustician should probably be involved. I am just curious whether all the standard acoustic rules are thrown out the window when using dipole speakers versus boxed speakers.
    Thanx,
    Harold
    Because I'm the man in black.........
  • AJINFLA
    • 681
    I would start with no treatment and proper placement (3' minimum, 4' better, from wall behind loudspeaker, 2' from side walls), then work from there.
    Dipole have completely different radiation patterns from monopoles. Getting late, so here are some good references IMHO (as opposed to me continuing to type)
    The acoustic behavior of rooms at different frequencies. The loudspeaker's polar radiation pattern determines its interaction with the room and the accuracy of sound reproduction. Reverberation time as most important parameter for a room's acoustic behavior.
    cheers,
    AJ
    Manufacturer
    • howburger
      • 44
      Thanx AJ, I'm totally new to dipoles and unfortunately I invested and installed all my room treatments just prior to getting the dipole bug. I can say that the imaging is amazing and the soundstage is unrealistically huge. They've got a little time before they break in and I will mess around with the room treatments some. It appears that my current absorption placement may not be too out of whack with what seems to work for others, according to the Opensky site. I will remove some at different locations and see how it affects the sound. It appears that with dipoles, diffusion may be better behind the speakers on the front wall as opposed to absorption. Thank you for the links. I've got a paradigm shift to deal with.
      Thanx,
      Harold
      • chasw98
        • 1360
        Harold:
        I have built a pair of the Arvo dipoles recently. I am finding that placement and treatment are a large part of getting the best performance from the speakers. In my room, I am also finding that too much treatment is worse than no treatment at all. Be very judicious in your use of treatment. I realize that you said it is already installed but you might think about taking some of it out to see the difference it makes. My room is too dead and I am now trying to liven it up. This also compares to ThomasW's experience with dipoles. He has a fairly lively room where mine is dead and we have gotten very different impressions of the same dipole loudspeaker. Just my .02.
        Chuck
          Play with placement until you get in the ballpark. Then 'map' the room using test gear. The ETF 5.0 website has a demo room example of room mapping.
          • howburger
            Request for Dipole MTM with Active Crossover
            by howburger
            Jon, this is a plea to you for an active dipole MTM using the Behringer DCX2496 that would provide a fairly simply constructed speaker with a downloadable crossover file directly to the DCX. I recall you saying that you were contemplating getting the DCX to mess with and to try to duplicate certain...
            10 April 2006, 16:59 Monday
          • jazznsoccer
            Serious room treatment effort
            by jazznsoccer
            Hi all,
            I’d like to thank all on this board :T for all of the great insight on gear. It’s been great and I’ve had a lot of fun with the setup. After using some nice gear for a while, the next step is to make sure the room acoustics are maximized prior to thinking about the next steps...
            23 May 2006, 00:22 Tuesday
          • dsl1
            Room Treatment With Statements
            by dsl1
            I am slowly working on the downstairs area and I'd like to get some room treatment. I started digging through the huge avs thread but I am wondering what I should do with the transmission channels / front wall.
            Here is the room:
            Dimensions are 13 ft wide,...
            29 September 2010, 09:50 Wednesday
          • howburger
            CD review website?
            by howburger
            Hello everybody:
            Is there a particular website that critically reviews cd's for not just the music content but specifically the recording quality? I would be looking for one that is searchable by artist and/or song and that is fairly vast in it's content. I love music and I have a system...
            11 February 2006, 17:42 Saturday
          • peterS
            DIY room treatment feedback needed
            by peterS
            want to make sure I'm absorbing this correctly
            here is what i would like to do:
            now it would seem that room nodes ar not very severe bellow 150 (unless i miss read this)
            I will have a sono tube in the left or right corner if that matters
            16 January 2007, 05:02 Tuesday
