Sub advice
  • Hallett
    • 102
    Sub advice
    Hello guys thanks for helping me get my new sys
    up and running . i have another question i have
    a new set of 804's and a bryston 4b-sst amp on
    order. will i need a sub to realy make my sys sing
    if so what sub should i get. thanks for your help.
    Classe ssp-600
    Classe CA-M400 Monoblocks
    Classe CDP-100
    B&W 802D :T ;x(
    Velodyne DD-18 :T
  • Kevin D
    • 4601
    Moving to the Audio Hideout, not Rotel related..
    Kevin D.
    • Hallett
      • 102
      Kevin D.
      Ok thanks Kevin my mistake.
      Classe ssp-600
      Classe CDP-100
      B&W 802D :T ;x(
      Velodyne DD-18 :T
      • dyazdani
        • 7032
        What is your budget? SVS are good subs in addition to some others. Is DIY any interest to you?
        Danish
          Sub Hunt
          by wkhanna
          I started a thread over at Audio Hideout concerning advice on my first sub purchase and with input from the maestro ThomasW, I would greatly appreciate any help from you guys.
          Here are some of the basic base lines I have established:
          I am making the transition from a 2-channel...
          26 February 2006, 13:20 Sunday
        • Hallett
          update on my new sys.
          by Hallett
          Well my new sys is coming along slow but should be together
          soon. i ordered a new veloodyne DD-12 today i hope it sounds
          good with B&W804's i'm looking at the modwright as a pre amp
          and have ordered the Bryston 4B-SST. what do you guys think
          about the modwright for a...
          22 August 2006, 00:43 Tuesday
        • bobhowell
          DIY Speakers for a Panisonic CD/Radio SYS
          by bobhowell
          I gave my wife a CD and Radio SYS, Panisonic- SA-PM53, several years ago. It has two speakers rated 6ohms each, but they are connected in a strange way. A set of connections go to the woofer, and a separate set to the tweeter. So are they customed to the system, with the crossover in the receiver side?...
          02 January 2009, 10:38 Friday
        • Trash
          1056 w/ Bryston 4BSST
          by Trash
          I'm looking into possibly trying out the new Rotel RSX-1056 for a new system and using it to power the center and rear channels. I am also considering going relatively 'big' for the L/R mains with a Bryston 4BSST.
          This results in a pretty big split between the center and mains (75 watts...
          13 January 2004, 15:00 Tuesday
        • dennyl
          Halo A21 vs. Bryston 4bsst
          by dennyl
          Has anyone extensively compared these amps with a good source and set of speakers? I am under the impression that the A21 is somewhat mellow in character whereas the 4bsst is extended but smooth. Also, both seem pretty equivalent in terms of power delivery. I will be using it with a pair of Thiel ...
          11 February 2006, 20:34 Saturday
