I'm a newbie that needs help deciding on speakers and subwoofer
  • eddiebrock
    I bought a house that had a dedicated theatre in it, but the owners took the projector, screen, receiver, as well as 2 free standing side speakers and the subwoofer. Someone suggested that I get these, which I think are the ones that were there before. Are there any comparable products that I should consider instead that might be a better for about the same price range?
    Velodyne SPL-1000 "10" (subwoofers)
    PR. B&W DS6 S3 2 Way dipole Surround ( Speakers)
    I don't even know where to begin looking. I believe my current speakers are B&W, I just need the 2 surrounds and subwoofer. Someone suggested getting the SVS PB12-Plus/2 or one of the SVS DD series for the subwoofer, but I don't know if there are speakers for about the same price that would be better than these.
    What I really need is a website or something that explains all the terms, technologies, and features I should be looking for in speakers and the subwoofer. I found a magazine that explained about receivers so I was able to make a decision on that, but I know absolutely nothing about speakers. My dedicated theatre is 24.8 x 15.5 x 12 and it looks like this, only its missing the surround speakers you can see on the wall:
    Twin Moderator Emeritus
    • 16706
    I'll give a second recommendation to the SVS subs :T
    As for speakers, find out what you've got for mains and match those, if your mains are B&W's your works almost done
    • eddiebrock
      Thanks for the quick reply. I'll be there tomorrow so I'm going to find out if they are B&W's. So you also think the SVS subs are better than the Velodyne SPL-1000 "10"? Without getting too technical, could you explain what it does better? I'm very happy two knowledgable people both recommended them, but its nice to know why.
        • 16877
        I agree with Jason--match the speakers.
        As for the subs, I'm another dual-SVS owner, and always recommend them to others. Great product.
          • 16706
          Velodyne makes great subs but they tend to be more money for the amount of sub you'll get compared to SVS.
          For one the SVS is a 12" sub, the Velodyne's only a 10". Lower, louder and cleaner are probably the best things to sum it up
          • jonathanb3478
            • 440
            And bigger!
            No one will ever accuse SVS of making dainty subs. I love my 20-39 CS-Plus, but the form factor is largish.
            Subs are just one of those things where bigger is better.
            -Vernon Sanders Law
              • 16877
              jonathan, have you seen SVS's line of box subs? They're no longer just cylinders. Some of the boxes are rather small. (I'm still a cylinder guy myself)
              • Vinny
                • 252
                The box sub from SVS is still huge, and heavier in terms of weight as well. My PB-12/V is like 110pounds, while the beast ultra/2 is getting to 200pounds!
                But the weight offers the degree of stability that you can use it as coffee table :B
                Pioneer KRP-500M
                Emotiva UMC-1
                Parasound 5125
                Oppo BDP-83
                Klipsch RF-3II, RC-3II, RB-5II
                SVS PB-10NSD
                • grit
                  • 580
                  http://i3.tinypic.com/1620hlk.jpg
                  Really, you're in luck. The surround speakers are the least critical in matching sounds, as is the sub. In a perfect world, you'd match the surrounds to the front 3 speakers. Pull the grills off and see what you've got.
                  Velodyne makes a great sub. B&W is more of a musical sub, but not what I'd pick for a home theatre application.
