Zenith Turntable Repair
  • manhattanman
    I found a late '70's Zenith sterio in the trash. The radio and tape deck works great. It is a 70 watt unit and would play 78 rpm records if the the turntable worked. The turntable is frozen--it will not move, and when the system is put into "phono" mode, it makes a low humming noise. How can I repair the turntable and where would I buy the parts?
  • Clive
    Former Moderator
    • Jan 2002
    • 919
    If you are a technician and can repair the unit yourself then your parts supplier would help in that department. If not, and supposing you're pretty handy, you're gonna have to figure out what part seems to need replacing and maybe search the web or find out where your local tv repair store get their parts from and go there.
    Short of all that....... the possiblility of finding available parts for that unit maybe pretty slim.
    CLIVE
    • BW4me
      Advice needed: repair or replace unit?
      by BW4me
      I have a DTR 5.5 paired with B&W CDMNT series speakers in 5.1 sound.
      Last April began having problems with unit just days before warranty ran out. Problem: unit turned on by itself and would switch between various play modes by itself. I got unit repaired under warranty, shipping...
      01 April 2009, 16:26 Wednesday
    • tinnsoldaten
      RSP 1098 details for repair
      by tinnsoldaten
      Hi everybody
      I got a RSP 1098 that have the typical loss of signal via optical , no relay sounds when I change sound mode. I also have no sound if stereo/bypass. I had it once at service but they sent it back "all ok "
      Now it worked for a short bit , but now...
      18 January 2016, 12:55 Monday
    • palmetto
      turntable stabilty - swivel shelf? speaker vibrations?
      by palmetto
      i have a technics SL-1300 (1976 vintage) and will resurrect it for my new ht system. it weighs, maybe, 25 lbs. (?).
      i am building a very solid wooden wall unit, floor to ceiling, with 20" deep shelves. but many of the shelves are not high enough to handle the 6"-15" opening...
      12 April 2004, 20:33 Monday
    • NancySpeed
      Vintage turntable help
      by NancySpeed
      Not sure if this is the correct forum. My 96 yr. old Dad and Mom just asked me to fix their ancient Zenith turntable. It does work but the problem is the arm that holds the needle. When a record drops, the arm goes all the way to the end, drops down, and then returns across the record to the middle...
      01 January 2005, 18:13 Saturday
      Heresy for an HTPC nut- the Zenith DVB318
      This little Zenith is one of those players that's getting a cult following do to possessing the right combination of features at a very reasonable price.
      Those features are dcdi Faroudja processing, DVI output, and HD upscaling on both DVI and component outputs- reportedly the latter...
      29 April 2004, 08:09 Thursday
