Pinnacle BDC 1200
  • GregLett
    • 755
    Pinnacle BDC 1200
    Has anyone out there heard these speakers? If you have what do you think.
    Thanks.
    Greg
  • GregLett
    • 755
    Well I purchased the Pinnacles to check them out. The build quality is ok. I would say they are worth every penny I paid for them $500,they retail somewhere between $900 and $1100. I would say in that range there are speakers better, but not by much. The binding post are 5 way medium duty, Ive used better, the cabinet
    is not that solid, but not too flimsy either.
    Sound:
    At first things were a bit grainy, and the base was thin. I figure since my equipment was off for
    quite some time, I wold give it some time to settle in. after leaving it playing for a few hours
    the base and treble improved quite obit. I have not really sat and listened that much as yet, and final placement has not yet been determined.
    So far the sound is encouraging, I'll have some fun with these for a little while.
    I will post some follow comments later.
    Greg
      Greg, I'm posting a link to the Pinnacle site showing the BDC-1200s. Those are some VERY attractive speakers. I hope they sound as good as they look! :T
      • GregLett
        • 755
        David,
        They sound great!! The only short coming is in the base area.
        I played all the recordings that I usually audition speakers with
        and these speaker performed ex extremely well.
        Due to the size of the drivers, some piano notes, and instruments
        didn't have all the wight as speakers with larger drivers, but that
        is to be expected. Other than that the midrange, and treble were
        excellent! The imaging was excellent!. Speakers I've heard that
        are better tan these are in the 2K and up range. I still have to replace
        my amp I'm currently using an old Rotel RB-980, I think I'll get some
        improvement from that change. Overall great speakers.
        Greg
        • jimmyp58
          • 1449
          I have these speakers in one of my showrooms. They are attractive indeed. And to your point, they lack in bass. A good sub can help a lot but if you are using them as standalone, they are thin in this area. And you hit the nail on the head with mid and treble.
          jpiscitello@ameritech.net
          • borntwice Hi-Fi
            Seeking Information about Pinnacle PN 6+ Bookshelf Speakers
            by borntwice Hi-Fi
            I just picked up a pair of Pinnacle bookshelf speakers, model PN 6+. I did find some information on Pinnacle speakers in general, specifically newer models, but not much about the model I purchased (they are too old to be listed on the Pinnacle site, apparently).
            They have 6.5 inch...
            16 January 2007, 22:11 Tuesday
          • av_dss
            804s vs Veritas 2.3i. Does it worth extra $1200?
            by av_dss
            I currently have a pair of Energy C-9. But looking to upgrade to something better. I've home auditioned a pair of Veritas 2.3i and loved the sound stage and the detail. Then......I got to this forum and the Rotel forum and many people here paired their Rotel with B&W 804s. ...
            05 May 2006, 18:28 Friday
          • kusum65
            too much base since upgrade !
            by kusum65
            Just upgraded my arcam 72 to a 192 and got a problem. The base has changed dramatically and with some recordings it engulfs the midrange. Ive got 601s in a small room and it took me a while to find the ideal room placement but i thought id cracked it and now this. With dance beats the base bounces around...
            15 July 2008, 12:41 Tuesday
          • Pete1974
            B&W Zeppelin Base Specifications
            by Pete1974
            Hi.
            Would anyone mind telling me the exact specifications for the tilt pad unit that the Zeppelin sits on please? I need to know the size of the Zeppelin base 'footprint' as I'd like it to sit on an extremely heavy but narrow, very unusual designed plinth.
            A photo or outline of the base...
            30 March 2009, 05:27 Monday
          • Bent
            ADA 1200 rumble filter
            by Bent
            The folks at Adire tech support have indicated to me that my ADA 1200 sub amp is equiped with a rumble filter set at 1.8 Hz. They said that by paralleling a pair of 11k resistors in the R48 and R51 positions (which should be 100K in each, as per OEM spec) should result in the cut-off frequency coming...
            21 April 2005, 10:13 Thursday
