No sound from Analog Multichannel?
  • Rolyasm
    • 382
    I recently purchased an SACD/AudioDVD player, the Pioneer Elite 47Ai. I know some folks aren't very found of it, but it was such a great deal I couldn't resist. Anyway, I bought an AudioDVD and I am not getting any sound from my channels. I am using a Denon 3801. I have the DVD connected to the Denon like this: I have the Analog 5.1 connected and I have the 2 RCA Stereo Connections. Dolby works great with movies, but I think the signal must be transmitting through the 2RCA's, because when I disconnect them, I get nothing. So it doesn't seem like my 5.1 connection is working. Any suggestions? If I had an I-link compatable receiver, it would be easier than the 6 connections, but I don't. :cry: Thanks for the help.
    Roly
  • gd
    • Jan 2003
    • 583
    Most likely you need to go through the initial setup of the player to establish a preference for multi-channel output... at least that's how it works on my low-end Pioneer uni.
    Then, of course, make sure to select multi-channel IN (or however Denon designates) on your receiver.
    greg (gd to you)
    Frank Zappa
    • Rolyasm
      • 382
      Ya, tried that. When I use Ext. In, it works, but only stereo. With Auto. select, Mulitchannel, Dolby, nothing comes out of any of the speakers.
