Cube, bookshelf, satellite speakers
  • saurabh
    • 329
    It seems so silly to ask this but just out of curosity what is the difference between cube, bookshelf, satellite speakers, is it only the shape, size or sound qualities also. Any pictures to show dissimilarities would be really helpful.
    Need is the mother of all Inventions.....I am needy
  • ajpoe
    • 439
    Cubes are generally very small, while bookshelves are usually bigger and either put on a bookshelf or stands of some type... either can be used as satelites. I would classify anything that isn't a full range tower speaker as a bookshelf with the smallest square speakers being cubes.
    AJPoe - - Growing old is inevitable, growing up is optional!
    • Preacherman
      Cube Advice
      by Preacherman
      I have 7.1 surround. My 4 dual cubes for the sides and rears are cheap-o RCA’s and I will be looking to upgrade. I am not a highly sophisticated audiophile however I would like some advice on nice sounding, moderately priced, cubes or speakers small enough to hang from the cube brackets.
      18 July 2004, 14:35 Sunday
    • saurabh
      Sound Opinion - Spk Stand, Spk Mount and Spk Bookshelf
      by saurabh
      Is there a difference in the sound quality if we place speakers on the Stands or Wall Mounts or an open shelf mounted on the wall specifically to keep the speaker, assuming they are all placed at the same height and direction and they are satellite speakers.
      29 March 2005, 04:30 Tuesday
    • 123Toid
      Cube Cubed - A Passive Radiator Build
      by 123Toid
      I have always loved passive radiators, so I thought I would finally do a build log along with all the parts needed. Thanks to Parts Express, I am able to bring one of these Passive Radiator Builds to life. My goal was to make a small subwoofer that would still have high spl, for a smaller room all...
      26 July 2017, 21:44 Wednesday
      Satellite Radio (XM and Sirius)
      I'm curious who has experienced satellite radio, and what comments you could make. Obvious attractions for using it would be national radio reception, diverse programming, and perhaps portable capability.
      But how does it SOUND, man, how does it SOUND? From what I understand, the audio...
      31 March 2004, 13:10 Wednesday
      Chroma Bug on Hughes E86 satellite receiver?
      I bought a Hughes E86 HDTV Satellite Receiver from Good Guys a few weeks ago. They're having a sale on them for $399, brought down even further to $299 if you buy any HDTV.
      So far the set has been great. Others have reported local channel reception being dropped by these units, but I...
      02 August 2003, 18:47 Saturday
