Greasing CD transport - what to use?
  • whoaru99
    • 639
    The belts finally came in for my Denon DCD-1560. While I had it disassembled, I cleaned up the old grease that was on some of the slides and tray drive gears.
    It kind of looks like plain ol' white grease. Could it be so simple? Or is there a certain type of grease that would be best to use?
    Todd
    ----JAFFE'S PRECEPT
  • Patt
    • 922
    White grease sounds like Lithium grease which I have seen on plastic and metal surfaces for lubrication.
    ......Pat
    • elbalok
      Aiwa Belts
      by elbalok
      Can anyone furnish me with information regarding Drive Belt & Tonearm belt sizes required for an Aiwa Steereo Turntable LX-70.
      Also, belts/sizes needed for an Aiwa Cassette Deck SD-F660E.
      Recommended sources for quality belts will be appreciated.
      Thanks...
      28 September 2010, 21:16 Tuesday
      CD Transport from across the pond...
      Sit back and relax, this is just another tale of weirdness with a little wonderfulness mixed in for goodmeasure (the best we can often hope for in life, no? )
      Sometime while I was at the movie and out to dinner, the folks from the post office dropped off a package I've been waiting...
      03 March 2002, 01:37 Sunday
    • wettou
      Using white noise to aim and adjust speakers
      by wettou
      Using white noise to aim and adjust speakers AIMING and "LEARNING" SPEAKERS Here is a method for "aiming" ...
      25 July 2010, 16:28 Sunday
    • Spearmint
      Cable length between transport and DAC
      by Spearmint
      I have a transport located away from my rack, I’m wondering if it’s better to have the DAC close to the transport and run 5 metre analogue RCA’s to the pre amp, or run 1x 5 metre digital from the transport to the DAC and using short analogue interconnects?
      30 April 2007, 06:53 Monday
      Retro Digital comes to town: The Avatar CD Transport from Denafrips
      Do you ever see something on the web and right away, your first reaction is "I gotta have one, muy pronto!"
      For whatever reasons, the new Denafrips Avatar CD transport struck that chord for me.
      As an aside, how many of you knew that in 2019 vinyl outsold...
      25 September 2020, 10:14 Friday
