well,
i was watching a movie, at a real good level, the sub cut out,
then come back on, then cut out.
made a ahhhhhhhhgggghhh sound and died....
before i give it a proper service and burial, with the brown box UPS truck coffin.
it didnt sound like a dead speaker kind of aghhh, it was more like a amp going aghhh...
i just got this sub less than a month ago, and was wondering if anyone knows or has any suggestions to try before i have to ship it out.
i tried diffrent inputs, checked the fuse
the red light is on, or the music sensor circuit works, it will turn on but no output
i pushed on the woofer, and it does move.. so the cone is not frozen, and the screws are not easy to get at to check the terminal for ohms.
i dont want to push voiding my warrantee so any other suggestions
you might have would be appricated.
bill
bill
